Thanks Thanks:  85
Likes Likes:  149
Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 441 to 480 of 593
Thread: MJS Mk4 Build Thread
  1. #441
    Dublin, OH
    Here's how mine's plumbed. 289 SBF
    Heater send coming off intake. Upper nipple on water pump for thermostat bypass. Lower nipple for heater return.
  2. Thanks MSumners thanked for this post
  3. #442
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by MSumners View Post
    About to run the 5/8 heater hoses, it mentions running the send line to the LEFT heater fitting. Does this mean left (driver side) or left as I’m looking at it (passenger side) ?
    I have always been told and followed the rule that anytime you are talking about left or right, it is as you are looking at the vehicle from the rear. So in this case, I would say it would be the fitting on the drivers side.
    Having said that, as far as the heater core goes, I really do not think it matters the flow direction through it. Hot water goes in, it gets hot, and air blows through it.
    And for what it's worth, mine is plumbed exactly the same as egchewy
  4. Thanks MSumners thanked for this post
  5. #443
    Correct. Left and right is always looking toward the front of the car. This side of the pond, left = driver side, right = passenger side.
  6. Thanks MSumners thanked for this post
  7. #444
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    Thanks for the input gentlemen, the picture makes it clear. Somehow I was thinking the send line was opposite what it really is.
    Finished up the wiring to my secondary fuse panel and time to re-test everything.
    Coupe Kit Delivered 11/10/23
    Roadster Build thread: 2019-2022 https://thefactoryfiveforum.com/show...4-Build-Thread
  8. #445
    Dec 2018
    Hudsonville, MI
    Is factory five releasing a motorcycle?
  9. #446
    Dec 2018
    Hudsonville, MI
    I finally have all the gear I need to finish up the 5/8 send and return heater lines to the engine and thanks again for the images above.
    I'm currently draining some coolant from the lower drain port on the radiator. If I drain enough from this position will it still pour out when I take the water neck off?
  10. #447
    Dublin, OH
    Your thermostat will be closed when the engine is cool, so I suspect you'd still lose coolant despite draining some from the radiator
  11. Thanks MSumners thanked for this post
  12. #448
    Dec 2018
    Hudsonville, MI
    Finished up the wiring to the heater and decided not to use the included switch, I just didn’t like the way the black plastic knob looked and anyway the push-pull cable was too short for where I initially intended to mount it. I ended up using one of the Ron Francis switches on the lower dash that’s a on-off-on. I will lose one fan speed but decided I’m ok with that. I wired up the medium and high speed and ditched the low. I figured if I’m ever using the heat or defrost I’ll likely really be needing it. I initially bought a push pull cable from Wag-aero that looked like it would work but ultimately I didn’t have the depth needed. I found this simple locking push-pull cable at Napa for a good price, it’s rock solid, smooth, and I like the way it looks. Otherwise finishing up the short list before the body goes back on for (hopefully) the final time before paint.
  13. #449
    Good luck with that flux capacitor. Heard those are hard to tune properly.
  14. Likes MSumners, WIS89 liked this post
  15. #450
    Senior Member Traveller's Avatar
    Jul 2019
    Grand Rapids, MI
    I've seen Mike's car, and am pretty sure he used the gen. 2 flux capacitor which is MUCH easier to tune (pretty much plug-and-play). However, I'm not sure if he installed the recommended 88 mph safety lockout. You can blow a lot of fuses running 1.21 gigawatts through that thing below that speed.
    Mike - That dash is looking great! Nice find on the pull/push cable.
    MK4 Complete Kit #9673 | Ordered: 08/07/2019 | Pickup: 08/24/2019
    Gen 2 Coyote, TKO600, IRS, Power Steering, 18" Halibrands, Kirkey Vintage Race Seats, Gas-N Headers and Pipes
    Build Thread: https://thefactoryfiveforum.com/show...IRS-Build-9673
  16. Likes MSumners liked this post
  17. #451
    Dec 2018
    Hudsonville, MI
    If there’s a chance I can go back in time and re-think some of my build decisions it’ll be worth it.
  18. Likes WIS89 liked this post
  19. #452
    Dec 2018
    Hudsonville, MI
  20. #453
    Dec 2018
    Hudsonville, MI
    I think this is plumbed correctly but figured I would post to see if anyone could verify?
    After running the lines as above I do have a small leak coming from the water neck. Its on the order of 1 drip every minute. Not sure what I can really do to fix it based on how I initially sealed it but figured I would see if anyone has any recommendations.
    To run the heater lines i used the ford water neck and tapped the extra port out to 3/8npt and attached the extra fitting (this does not leak). I cleaned off both the water neck and the attaching point well and applied the permatex sealant in a thin layer to both sides of a new gasket. As instructed attached and put the bolts in finger-tight then let it set for 1 hour before final tightening. I read somewhere maybe 18-20ft /lbs but most people just wing it because its difficult to get an adequate torque wrench in position, and thats exactly what I did. Not sure if there is a better process or sealant recommended?
  21. #454
    Dublin, OH
    I used black ultra RTV I believe. Where is your fitech temp sensor? In the intake?
  22. #455
    Dec 2018
    Hudsonville, MI
    Yep this is where it came installed.
  23. #456
    Dublin, OH
    what do you have threaded into the bung on the PS front of the intake? I have my heater coming off my PS front, my Fitech coming off the DS front as you do, and my water temp sender coming off my water neck. it's probably going to work all the same. good luck with the leak. Napa will rent you a coolant system pressure tester to identify leaks.
  24. #457
    Dec 2018
    Hudsonville, MI
    The PS is the temp sender for the gauge. I think I’ll retry with a new felpro gasket and see if I still have trouble.
    Quote Originally Posted by egchewy79 View Post
  25. #458
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I had problems with my water neck leaking as well. The final fix for me was to order a Ford OEM performance water neck using RTV and good Fel Pro gasket. Let it set up over night before trying to run it. There is also a trick when installing the thermostat using a few small dabs of RTV to hold it in place so it does not move when you place the water neck to the intake manifold. If you do not do this it will move around and cause problems with the sealing.
    What water neck are you using?
    This neck was what I ended up ordering and it solved all the problems.
    https://www.cjponyparts.com/ford-rac...CABEgJt1vD_BwE
    Build #9818 completed 04/2021 - Dart SBF 427, PF4 EFI, TKO600 Build thread: https://thefactoryfiveforum.com/show...utton-head-mod
    Build review video:https://www.youtube.com/watch?v=k6IAbo2sFt4&t=1111s My finished car: https://thefactoryfiveforum.com/atta...7&d=1638415131
  26. #459
    Dec 2018
    Hudsonville, MI
    Thanks for the recs! Yep that’s actually the same water neck I’m using. I just tapped the extra port to 3/8 npt.
  27. #460
    Jan 2020
    State of Jefferson
    Did you secure the T-stat when installing? RTV on front and back side of gasket and let it sit overnight?
  28. Thanks MSumners thanked for this post
  29. #461
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Quote Originally Posted by Fman View Post
    I would guess this. I spent sooooo much time on this leak. I was finally able to get sealed up a while ago. When I open the hood, sometimes I still have flashbacks of seeing coolant pooled on top of the water pump on each side
    I did not use RTV on the Fel Pro gasket, but used three dabs to hold the t-stat in place and letting it sit overnight before installing to keep it from slipping out of place.
  30. Thanks MSumners thanked for this post
    Likes Fman liked this post
  31. #462
    Dec 2018
    Hudsonville, MI
    I did secure the thermostat and coated both sides of the gasket. However I didn’t let it sit overnight prior to install. I’ll give that a shot on the next round. According to FelPro website using rtv with their gasket can actually make it more difficult to seal so maybe I’ll simply clean it and retry with only a new gasket.
  32. #463
    Dec 2018
    Hudsonville, MI
    Update on the water neck leak. It was the felpro gasket for the win. Didn’t use any RTV this time just cleaned everything up again and bolted it back in with a new gasket. I was able to heat cycle it a few times and at least to this point no leak at all. Last leak to fix up is at the hydraulic clutch line to the master cylinder connection. It is the smallest of leaks and doesn’t even form a drop over time but I can feel the brake fluid on the exposed threads and have been tracking it for weeks, I have a new brass wilwood adaptor ordered and I’m optimistic that should do it. Everything at this point mechanical and electrical is working as it should.
  33. Likes Fman liked this post
  34. #464
    Dec 2018
    Hudsonville, MI
    I was able to get the clutch connection leak sealed. Ordered the actual wilwood 3/8-24 to -3 fitting and installed then re-bled the line. Not exactly sure why this one works so much better as it looks just like the one I exchanged it for. Nonetheless it’s switched out and not even a trace of fluid after holding the pedal to the stop for over two minutes.
  35. #465
    Jun 2019
    Las Vegas, NV
    One of my brake fittings did the same thing. Just a little bit of a leak. I tightened a little bit, no change. I took it apart, inspected, and reassembled. No change. The hell with it! I replaced the fitting and it has held for 5K miles now. IDK, some parts just don't like to fit together.
    I'm glad you fixed the water neck leak. It sucks having to dump coolant out the front of your motor each time you try to fix it. Both you and I are experts in water neck removal! Watch your brass 90 degree fitting and make sure that it does not come loose. I was having problems with mine. After a few hundred miles and lots of heat cycles, mine kept coming loose. Also, because of the 90 degree bend, I would have to remove the upper hose in order the turn it past it. I ended up replacing mine with an aluminum fitting that was straight. That way I could easily turn it if needed to again without removing the upper hose. Of course, the needed a new 90 degree bend heater hose....... It never ends
  36. #466
    Jun 2019
    Las Vegas, NV
    I noticed that you have the vacuum advance port on the distributer capped off. Is that something that is not needed with the FiTech?
  37. #467
    Dec 2018
    Hudsonville, MI
    When I was first getting the engine going I had messaged Mike Forte about it and he said to get it running and driving first without it. Glad you reminded me actually I need to look into this some more. I can say at least at my go cart speeds (<25mph) everything runs normally. Can’t say I really understand the vacuum advance too well yet specifically with the Fitech and the way it is setup so I have more reading to do.
    Quote Originally Posted by TMartinLVNV View Post
  38. #468
    Jun 2019
    Las Vegas, NV
    I'm not an expert and I did not sleep in a Holiday Inn Express last night. There is a lot contradictory information out there. This is a good article:
    https://www.hotrod.com/articles/ever...nition-timing/
    Go down to the section called "Where Should the Vacuum Canister Be Routed".
    Buy about 5 ft of 3/16" vacuum line. This will connect the cone thingy on your distributer to the back of your throttle body. There will be two small ports there. The lower one (probably in the middle) is "manifold vacuum". The slightly higher one (probably on the right side) is "ported vacuum". I have mine connected to the manifold vacuum port. This was suggested to me by Skidd and I did a bit of reading about it afterwards. You can run the line under the throttle body in the valley of the Air Gap intake, and trim to fit. Make sure that the other port is capped off.
    Research your FiTech options. I have the Holley Sniper.
  39. Thanks MSumners thanked for this post
  40. #469
    Dec 2018
    Hudsonville, MI
    Finished fitting the Cipher belts and the attachment points.
    Next up is continuing to work on some panels to decrease the amount of sheer metal in the dash area and glare. Using the weldwood solvent adhesive, 1/8”foam and some left over black leather. Not to any versions I would consider ‘keepers’ yet but getting closer and getting the methods down, probably a few more versions as usual until I land on something final.
  41. #470
    Dec 2018
    Hudsonville, MI
    Lots of standing , staring and cutting foam templates.
    Not quite yet but getting closer.
  42. #471
    Dec 2018
    Hudsonville, MI
    20-30 minutes of progress daily.
    I decided to track down any gaps I missed in sealing the foot boxes. I put my headlamp on flash mode, placed it in the foot boxes and turned the garage lights off. Easily lit up a couple small areas I missed. Now confident they are completely sealed.
  43. Likes WIS89 liked this post
  44. #472
    Dec 2018
    Hudsonville, MI
    Great day for some go cart action and to test out the new flow valve on the KRC power steering pump. Night and day difference and feels so much better. I was able to mount a small reservoir and pump for a windshield washer jet and also mount the rear wall speakers. I think this is truly the last wiring to do and should be quick.
  45. #473
    Dec 2018
    Hudsonville, MI
    I’m working on finishing off the trunk area before the body goes back on and started laying out the carpet sections. The placement of most are obvious but there are a few I just can’t seem to get right.
    Are all of the walls of the foot boxes supposed to have carpet sections?
    Anyone recognize these two?
    Anyone have pictures on a finished car of the upper corner near the rear of the door? Trying to envision what this carpet is going to look like and if the overhang from the body covers the edge.
  46. #474
    Dublin, OH
    Yes, footbox walls are covered. Looks like your PS footbox pieces. That notch is for one of the round tubes. The medial footbox piece isn't in the pic. It has a larger oblong notch for the 4"round frame.
    edit: I think the bottom piece looks like the piece for the DS outside footbox kick out area.
  47. Thanks MSumners thanked for this post
  48. #475
    Dec 2018
    Hudsonville, MI
    2 years ago today and the most recent progress. Still rolling along 30 minutes here and there.
  49. #476
    Dec 2018
    Hudsonville, MI
    Leather wrapped and test fit the trans tunnel cover and now working on fitting the Lokar boots. Fits like a glove. The landau top and trim adhesive that gets discussed fairly frequently is amazing for this work and would highly recommend it. After cutting the holes for the shifter and Ebrake I used a small syringe and 18ga needle to re-adhere the edges really well.
  50. #477
    Dec 2018
    Hudsonville, MI
  51. Likes JB in NOVA liked this post
  52. #478
    Oct 2020
    Albany, NY
    Your cockpit looks like a WWII era fighter. It’s cool as hell.
  53. Thanks MSumners thanked for this post
  54. #479
    Dec 2018
    Hudsonville, MI
    Working on the side louvres and I’m using the HSRF bonded studs for mounting as I saw in Paul’s thread. Works great and as always the forum comes through with an elegant solution. First time using HSRF and I’m glad I really watched where it was going that stuff is hard as rock when it’s cured. Glad I didn’t have to clean much.
    4 cycles of ‘fit-mark-remove-trim-clean-check’ and the passenger side is not quite completely done but getting close. The individual fins look like they are 40mm apart and that’s what I used to mark the edges on either end.
    (If anyone needs the basic louvres sent with the kit feel free to PM and I’ll send em out)
  55. #480
    Oct 2020
    Albany, NY
    On your trans tunnel, did you put anything between the leather and the metal or adheres directly to it?
