0
Coyote Moroso oil pan interference question
I received my Gen2 Coyote last week, and my Moroso oil pan and pickup (and a bunch of other fun stuff from Mike Forte) arrived over the weekend so I can start some of the engine prep and flywheel/clutch assembly.
Regarding the Moroso oil pan installation, several people have mentioned in their build threads that the dipstick interferes with the baffle that's right under the oval cutout in the oil pan. Is this pretty much a universal issue? Should I just go ahead and cut away the offending bit of that baffle before installing the oil pan, or does it vary from engine to engine? If it's common, does anyone have any pictures of how much and where they cut away?
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
