0
0
abs wiring question
In my build I will incorporate a 4 channel abs system utilizing the following components: 2015 mustang irs; 94 mustang front hubs; 97 mustang hydroboost, and 2007 GT500 abs module (ala Johngoerge racing setup). Now on to my question. The sensor wiring appears to use a twisted pair type of wiring. What have people used to wire the sensors to the module? My thought was to use shielded CAT 5 cable. The other possibility that I could come up with was door bell/thermostat wire run in individual looms to avoid potential for cross induced signals but I don't know if that is a concern. Recommendations appreciated.
The twisted pair is a must and the wiring may need to be impedance matched to function correctly. I got the wiring from a salvage yard so the connectors would match up and the controller would be happy.
