Thanks Thanks:  29
Likes Likes:  194
Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 441 to 480 of 603
Thread: What did you do on your roadster today?
  1. #441
    Senior Member NiceGuyEddie's Avatar
    The LBCeeeee
    It's been 4 months since my snakebite and the first relatively cool day since last summer began.
    I started up the car to get things circulating and up to temps.
    The 6-year-old Optima battery struggled a wee, but it turned over and idled ice cold at 650rpm. (I have no choke plate.)
  2. #442
    Senior Member Kodiak's Avatar
    Jun 2020
    Pinckney Mi
    Fitting and drilling more sheet metal. ��
  3. #443
    ...................I Brought Redbone Home Once More!
    This Hurricane Season Has Been A Real Pain In The Neck Among Other Body Parts!
    ...............https://en.wikipedia.org/wiki/2020_A...ummary_map.png
  4. Likes nucjd19 liked this post
  5. #444
    Sep 2011
    Minneapolis, MN
    That's just a bummer! I hope you've avoided the damage, in return for work and stress.
    For my part, picked up 24" x 36" copies of the RF electrical schematics and some masonite sheets to mount them on yesterday, to get ready for the next deep dive into something I know nothing about.
    This morning, snuck out to the garage before work to inspect all the brake lines after adding brake fluid and bleeding brakes over the weekend ... no brake fluid showing anywhere, so ready to move on.
  6. #445
    Senior Member bobm488's Avatar
    Sep 2014
    Temecula, Ca
    I started the process of painting my GEN 2 Coyote engine and coil covers.
  7. #446
    RJD's Avatar
    Northern Virginia
    Made a front license plate bracket. Yes, I know ... but it's the law. Besides, I had extra sheet metal left over from the build.
    Riveted to a blank plate from Amazon
    More extra metal
    Bent and riveted that piece to the blank to give the plate some strength and forward spring loading.
    8FC0DE3A-0625-465C-8549-BEF3B61C06BB.jpeg 9A708FC9-099C-4869-8E3C-F4E614641532.jpeg
    Complete
    A0725EB0-4F7E-4F0E-A819-1AD7FF9620A4.jpeg 08852956-F9E9-46DD-94ED-190D8D3B9406.jpeg
    Took it out for a test drive on some rough roads and on the freeway and there was no rattle nor contact with the body. Seems pretty solid.
  8. Likes Rook, jrcuz liked this post
  9. #447
    Sep 2014
    Temecula, Ca
    Looks nice
  10. Thanks RJD thanked for this post
  11. #448
    On a roll Al_C's Avatar
    Wheaton, IL
    Gave it a good cleaning. (got caught in the rain last weekend and it was a mess) I'm afraid my season may be over and I have to put it away for winter. Hoping for another nice day...
  12. #449
    Senior Member Norm B's Avatar
    Decided the driving season was over a few days ago. Added fuel stabilizer, filled the tank, put it on wheel dollies, changed the oil, installed the top, gave the car a quick wash, put the cover on and shoved it in the corner of the garage to give my wife as much room to park as possible. Looking forward to spring already.
    Norm
  13. #450
    Quote Originally Posted by RJD View Post
    More extra metal
    Complete
    Cool!
  14. Thanks RJD thanked for this post
    Likes Kmcallahan liked this post
  15. #451
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    Mounted new shoes, actually the first set. 0A9B865C-5C19-4BB2-9D5D-B8C58F382447.jpeg
  16. Likes toadster liked this post
  17. #452
    Jun 2020
    Pinckney Mi
    Installed IRS today .
  18. #453
    North CT
    I let her sleep in the garage.
  19. #454
    I guess I'll move Redbone it to higher ground once more since we've got another tropical system headed our way.
    NOLA Weather:
    https://youtu.be/WcbwBnDIUCc
    Houston Weather:
    https://youtu.be/u3RRXpYBUfo
    The year has been a lot like 2005 down here on the Gulf Coast.
  20. #455
    Oct 2018
    Shamelessly stole skidd's idea to make a functioning horn button in the steering wheel like the way it turned outIMG_08471.jpg
  21. #456
    Ancaster, Ontario
    My j-pipe/side pipe combination on the driver’s side has been slipping down gradually due to the adjustable manifold / j-pipe connection. The poor quality rubber hanger on the side pipes is not helping either. I installed this stainless turnbuckle purchased on Amazon to suspend the system and prevent further downward movement. The system is free to move upwards as I used two chain links to attach the turnbuckle to the 3/4” chassis member. I also sourced a much stiffer rubber exhaust hanger at the local pick and pull. Fingers crossed!
    MKIV #8740, Canadian base kit, Picked up Dec. 2015, ‘98 Cobra 4.6 l DOHC, T45 transmission, old style IRS, Art Cuesta dieted harness/Ron Francis chassis harness, go-cart July 2018.
  22. #457
    Jun 2020
    Pinckney Mi
    Dropped off sheet metal to powder coater.
  23. #458
    I brought Redbone home from my brother's house (Again).
    We've stored it there for every storm (Hurricane) that came to visit us this year.
    I then took my baby girl for a ride (Emma age 27) and after that, I took my pal Matt for a ride too.
    To say the least, it was a very nice day so I'm now enjoying one of my favorite Tequilas because I'm out of Scotch!
    Redbone:... https://www.factoryfive.com/whats-ne...-mk4-roadster/
  24. #459
    Sep 2014
    Temecula, Ca
    Went to breakfast with the wife then a quick canyon run.
  25. #460
    .I Drove The Sucker About 10-12 Miles!
    Finally, No Freaking Hurricanes Came Our Way!
  26. #461
    Sep 2019
    Bothell, WA
    glad you are getting a break from the weather!!
  27. Thanks GoDadGo thanked for this post
  28. #462
    Feb 2020
    Chicago
    Im telling!!
  29. #463
    Wife and I made about 50 mile local cruise. I got my 4 corner balance corrected, thanks to Jeff K.
    Rear does not feel as loose in a left hander now.
    I clocked my MAF sensor tube and engine feels cleaner below 3K rpm.
    Brakes feel like they may be requiring less leg, 1100 plus miles. Wilwoods 6 and 4 pistons.
    Checked my tire pressure and set everything to 23# per my cheap gauge. Need to go back to 22#. 23 feels like it wants to dribble a little.
    No new rattles or squeaks. Wife said she kept hearing something. It was me whistling.
    Got to get those Speedhut gauge lights fixed, before paint day.
  30. #464
    Jun 2017
    Norway
    Did some more tuning of the engine after replacing the IAC valve with one that fits. Love the raspy sound of the stacks!
    https://youtu.be/5-S5aoWKv58
    Test fitted the body for the first time, which also was a test of the contraption I made to be able to put the body on and take it off by myself. Worked great!
  31. Likes Straversi, RJD liked this post
  32. #465
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    More extra metal
    Complete
    Nice work! I am registered in VA as a 1965 with Vintage plates, so I keep my front plate in the glovebox.
  33. Thanks RJD thanked for this post
  34. #466
    Folsom, CA
    Getting back onto it - drilled and set the passenger floor panel
    Todd
  35. #467
    RJD's Avatar
    Northern Virginia
    I started upgrading the cockpit carpeting. The Home Depot outdoor carpeting was good for the trunk, but I wanted something more plush for the cockpit.
    Old:
    New- still needs to be glued down:
  36. #468
    I Put On My Hunting Jacket, Baseball Cap & Went For A Joy Ride & Guess What?
    I Enjoyed The Drive & Embarrassed A Young Fellow In A Mustang!
    With That Said, It's Good To Be The King!
    Thanks For Quote Mr. Brooks!
    Mel Brooks That Is!
  37. Thanks Kmcallahan thanked for this post
  38. #469
    Sep 2019
    Bothell, WA
    Centered the steering rack and did rough alignment!
  39. #470
    I Put On My Hunting Jacket & Went For Another Joy Ride Today!
    When I left the house it was 39-F so it was not bad at all compared to my former motorcycling excursions.
    I cruised to my pal Dave's how to see how he and Sammy were coming along on Dave's 33 HR.
    They've finished the bodywork and were sanding away getting it ready for paint.
    They hope to prime the car next weekend.
    NOTE:...Yes Dave's Car Is Chevy Powered Thanks To BluePrint Engines!
    .............The 400 Small Block Dyno Pulled Right At 517 HP!
  40. #471
    Took My Wife Out For Steak Night @ Restaurant Cote!
    .................https://restaurantcote.com/
    ........It's nice to be able to be old and eat early!
  41. #472
    Jun 2020
    Pinckney Mi
    Mounted the seats in .
  42. #473
    Sep 2014
    Temecula, Ca
    Took a nice drive into the canyon.
  43. #474
    Jax Beach, FL
    I have my differential and pinion out for a bad bearing. I am going to have to pull the housing out because I cannot get the rear bearing race to go in from under the car. I even put it in the freezer. It was a PITA Royale to get the old one out.
    Hopefully all back together this weekend. I am missing some sweeeeet Florida driving weather.
  44. #475
    RJD's Avatar
    Northern Virginia
    Went on a cruise along the Potomac river to George Washington's Mt. Vernon estate and back. Thanks to the Cobra Heat seat heaters, it was a pleasant ride even at 48 degrees.
  45. Likes jrcuz liked this post
  46. #476
    Jul 2019
    Midland tx
    Elk Grove, NorCal
    Drove to work 100 miles away. Drove home the next day but took the long way home...150 miles. Added 250 total miles on the odometer this weekend.
    Kit purchased: July 25, 2017
  48. #478
    Albany NY
    I drove my roadster to the State University of New York at Albany, where I got my first dose of the covid vaccine! Thanks to the National Guard, for taking such good care of us. It was about 30 degrees out, but the roads were clear and it wasn't raining, so why not drive the cobra?
  49. Likes phileas_fogg liked this post
  50. #479
    Sep 2015
    Beachside
    Looked at my car hibernating under a cover while more snow fell. Love Boston in Feb.
    FFR #8833 289 FIA 3-link
  51. Likes Al_C liked this post
  52. #480
    Removed the donor rear springs and shocks and added coil overs.
  53. Likes RJD, GoDadGo liked this post
