Likes Likes:  5
Results 1 to 27 of 27
Thread: Dave's 818C Build
    Mar 2019
    Dave's 818C Build
    Like many other guys, I want to document my build. So here we go.
    The beginning, Feb 24, 2019
    Fenton MI
    looks to be a good donor, was it a run and drive?
    Factory Five 818c #456
    Mar 2019
    Thanks Shawn, I only cranked in over and let it run for a brief moment in my driveway when I got it home. I do plan to do a full rebuild of all the components I'll be using. Fortunately for me, I have a friend who is a sub tech.
    Mar 2019
    Mar 2019
    Jonny 5 here became my best friend in the garage.
    Mar 2019
    Mar 2019
    Mar 2019
    Finished the disassembly of the donor
    42 hours, working by myself and the donor is stripped. Now for the parts cleaning part, ugh.
    April 7, 2019
    Fenton MI
    yep, this all looks very, very familiar...
    so it runs? sometimes subarus will jump timing in front end collisions.
    When does the kit arrive?
    Mar 2019
    Last I contacted FFR, they were taking orders for 4-6 weeks out. I will place the order this week. Then I have a bit of work to do on my trailer. I plan to ride up and pick up the kit myself. I'd love to see the facility. Is your car done?
    Fenton MI
    Not even close to being done, little time and family have taken priority. taking a look around FFR is definitely worth the trip!
    Mar 2019
    Away she goes
    Kit order placed, expected availability for pick up, May 18, 2019
    Mar 2019
    This is going to be a very long two weeks. Doing as many house chores as I can before I pick up my kit. Everybody knows that once it is here Dad will be moving into the garage.
    Senior Member DSR-3's Avatar
    San Jose, CA
    Or you could just bail on the chores and clean up/prep the engine and trans...
    818S #332, EZ30R H6, California licensed 01/2019
  15. Likes Shawn818c liked this post
  16. #15
    Mar 2019
    I like the way to think brother.
  17. #16
    Mar 2019
    The day has finally come. Rolling out in a few hours from Philly to Wareham to pick up my kit in the morning!
  18. #17
    Mar 2019
    Spent most of the day in the garage. Got the chassis moved in, unpacked and all of the body and Subie parts stored away. Ready to begin this build.
  19. Likes Mitch Wright liked this post
  20. #18
    San Jose, CA
    congrat's on what is always a great day! It seems like last week that I was emptying a U-Haul full of 818...
  21. #19
    Mar 2019
    Well progress has been limited to the underbelly aluminum and I've ran into my 1st issue. The "OEM pedal box front plate" I didn't see that anywhere in the disassembly instructions and apparently didn't keep it. Hopefully someone has an answer other than, find one in a junkyard.
  22. #20
    Mar 2019
    I was confused by that at first too. What they mean by OEM is that the plate is to attach the pedals from the donor as opposed to the wilwood pedal box which must come with its own mount. The plate is supplied with the kit. Mine was in box 8C. Assuming they box all the kits the same.
  23. #21
    Jul 2017
    The Villages Fl.
    It is shown on page 80 of the manual.
  24. #22
    Mar 2019
    Thanks guys, I found it.
  25. #23
    Mar 2019
    I was having the same trouble as many others, replaced front C/V joint/axle shafts, on my donor. Mine happened to be NAPA axles. I spent quite some time with my BFH (Big $%&#@!* Hammer) working on one of them. I believe I found an easier way.
    Attachment 109435
    Attachment 109436
    Thanks to my buddy Jay. He's the handsome yet camera shy person at the controls of this adventure.
  26. #24
    Senior Member Jetfuel's Avatar
    Aug 2018
    If the BFH doesn’t work the blue wrench will do the trick every time
  27. #25
    Quote Originally Posted by davidstrother View Post
    Attachment 109435
    Attachment 109436
    Pipe trick
  28. Likes Mitch Wright liked this post
  29. #26
    Mar 2019
    Front suspension and steering rack nearly complete.
  30. Likes Mitch Wright liked this post
  31. #27
    Mar 2019
    So on chemo days they give me steroids as well. I know this and usually take a sleeping pill that night, knowing that I won't be able to sleep. So what happens when I don't take said sleeping pill? I get a lot of work done on the car, 11:30 PM. till 6:00 AM. in the garage. Got the accelerator pedal bracket holes drilled, steering column in, learned that the holes should be drilled before the column is installed. Removed the pedal box three times I think, anyway made a lot of progress.
    466M4BSpScqaFxY4TYSsLA.jpgkJ1Q2Z2HTwe6Vl3OsobIcA.jpgMiR1q7S%Sy+ti2iMNB8Olw.jpg466M4BSpScqaFxY4TYSsLA.jpg
  32. Likes heybluez liked this post
