Thanks Thanks:  15
Likes Likes:  211
Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 271
Thread: SS383 Build - 33 Hot Rod #1134
  1. #121
    May 2018
    Pinckney, MI
    Insulation and noise reduction
    Installed the firewall part of the kit before
    I start putting all of the stuff on the frame here.
    Before
    After
    Deciding when to do things is an interesting challenge with the build.
    - Peterh226 #1134
  2. #122
    It mounts with the hose inlets up.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  3. #123
    Quote Originally Posted by peterh226 View Post
    Before
    After
    i wish they told,you, but you have to cut the insulation back an inch for the body lip.....
    Titled 2-28-20
    MkI.IV 2643k
  4. #124
    May 2018
    Pinckney, MI
    Quote Originally Posted by sethmark View Post
    LOL. I was poking holes in the stuff forgetting it would need to be flush! Thanks for the reminder. Order of operations and interdependencies is really crazy with building a vehicle.
    - Peterh226 #1134
  5. #125
    Man you said that nicely. The hardest part is knowing what’s next after what’s next.
    Titled 2-28-20
    MkI.IV 2643k
  6. Likes GoDadGo liked this post
  7. #126
    May 2018
    Pinckney, MI
    At this point I know how most of the systems will fit together, it now deciding when to drill holes to mount the seats (like while you can still see the frame). I'm thinking that I am ready to put the composite floor in so I can the fit the transmission tunnel.
    - Peterh226 #1134
  8. #127
    Village Mills, Texas
    might have disappeared when I deleted the FFR gas tank....
    I don't think they came with the Gen 1, but I had the tank delete also, so I'm not sureIMG_1049.JPG. I purchased one from Amazon and piped it to the purge valve then created a circuit with a mini time delay relay to power it. It energizes the purge valve for 30 seconds when you crank it.IMG_0090.JPG
  9. #128
    May 2018
    Pinckney, MI
    Excellent. Thanks!
    - Peterh226 #1134
  10. #129
    May 2018
    Pinckney, MI
    Gen 2 floor
    I had drilled the holes underneath before mounting the engine so I could turn the frame on it’s side. I’m not a fan of metal shavings near my eyes. So I just needed to drill the top side panels.
    Once that was done i checked the fit of the structural panels and sanded a little bit to get them to fit.
    I attached the lower panels. They are powder coated argent so will look ok from below. Next, I checked the fit of the panels.
    The white stuff that FFR recommends is pretty easy to spread. I used about 98% of the 4 tubes. Spread it around so it will stick on all sides.
    Attached the top panels and it’s starting to really look like a car.
    I used a harbor freight pop-rivet air tool and that is a lot easier on the hands.
    Acetone is you friend to keep the white glue from being a mess everywhere.
    The floor feels really solid with this composite construction.
    - Peterh226 #1134
  11. #130
    I was really happy with the floor. Seems to eliminate heat intrusion too..
    Titled 2-28-20
    MkI.IV 2643k
  12. Likes peterh226 liked this post
  13. #131
    May 2018
    Pinckney, MI
    EFI Fuel Pickup challenge
    As the Gen 2 folks have seen, the fuel pickup and the body have a fight about trying to share the same space. So, after seeing this problem and realizing the waterfall would only make it worse, I decided the only fix was to change the orientation of the pickup stuff.
    Here you can see I've twisted the pickup tube along the length so it will better fit into the sump area of the fuel tank.
    Here a little welding to put it back into place.
    Now you can see the orientation of the pickup and the outside tubes.
    Of course the holes in the top are indexed so it will only mount 1 way. I drilled one new hole and relieved a couple of the others so it would fit
    And here you can see the result with the body in place.
    Never a dull moment. I hope this works OK.
    - Peterh226 #1134
  14. Thanks shmelty thanked for this post
    Likes Mrallsport32, wrp, FF33rod, shmelty liked this post
  15. #132
    May 2018
    Pinckney, MI
    Gen 2 Exhaust, Driveshaft, rear trans mount interactions ARRGGHHH
    Hi folks,
    I've got a Small Block Chevy with TKO500 (Blueprint). Also using a Moser 3-Link rear end. Gen 2 has some new wrinkles with new the composite floor - I think it will be great, but causes some vertical exhaust clearance issues. At this point everything is close, but not quite fitting and I'd like some advice.
    - The exhaust is very close to the floor. It seems like the new floor needs new Header pipes that would drop the flange down about 5/8 - 3/4 of an inch so everything would fit OK compared to the old Gen 1 exhaust.
    - If I drop the rear of the transmission down, I gain enough clearance on the Driver's side exhaust, but it's still a bit short on the passenger side. Also this reduces room for the driveshaft.
    - The drive shaft needs to run almost parallel to the floor. If I let the rear suspension hang down, then the driveshaft will make contact at the rear of the floor. I don't think this is a good idea!
    Options I'm considering:
    - Mount the transmission as close to the floor as I can at the back while still having clearance for the driveshaft yoke. will probably end up with ~1/4 to the floor at the housing, but I could cut away some of the transmission housing to get a little clearance. I'm more concerned about the driveshaft yoke as the limiting factor.
    - The passenger exhaust transition piece just seem like it is not going to work as is. It needs to be about ~5/8 lower at the flange to have the rest fit OK.
    - I'm worried about the driveshaft and the axle at droop when unloaded. Has anyone tried adding cables or something that would hold up the rear axle if you jack it up even to change a tire? The maximum distance I am seeing between the top of the axle housing and the top of the frame above is about 9-1/2 inches. If the axle droops more than that, then the driveshaft is gonna contact the floor. It looks like if the rear axle goes up (so that clearance drops to maybe 7-1/2 inches) then the top link may touch the frame.
    Here's some pictures to illustrate what I'm seeing. I will be getting my wheels and tire next week so I can drop it down and see the rear axle location.
    Here you can see the transmission at the lowest it can go without cutting away some of the housing. The Yoke has very little clearance at the back edge with the Rear axle being supported.
    This is a squirrel's eye view of the passenger exhaust flange. It's just too close to the frame and there is no adjustment available since the muffler and emergency brake have some space needs farther back. Since I will have to raise up the transmission 1/4 to get at least a little clearance, that will only make this area worse.
    Anyone else with a Gen 2 and SBC seeing something like this?
    - Peterh226 #1134
  16. #133
    1. I’m running the coil overs in the top set of holes to limit droop.
    2. FFR sent me extra exhaust spacers which I stacked and welded to get exhaust clearance.
    3. It all works. But it does require some dialing.
    Titled 2-28-20
    MkI.IV 2643k
  17. #134
    May 2018
    Pinckney, MI
    The tail of your transmission is way higher than I’m looking at. Have you checked your pinion angle?
    I’ll try the various mounting holes at the back once I have the wheels and tires.
    I think that doing whatever I need on the exhaust downtube will be what i need to do.
    - Peterh226 #1134
  18. #135
    That particular picture is apparently before o adjusted the motor height. The transis as low
    as possible. I’m sorry I picked the wrong photo.
    Titled 2-28-20
    MkI.IV 2643k
  19. #136
    May 2018
    Pinckney, MI
    No problem. I’m more worried about the driveshaft and the rear end. I’ll see what that looks like with the wheels in place and the go from there on the exhaust.
    - Peterh226 #1134
  20. #137
    It all took some dialing. The relationship between engine and rear axle is critical, of course. I have a lot of time in it. But it works.
    Titled 2-28-20
    MkI.IV 2643k
  21. #138
    I have a gen 1 and have the rear suspension jacked up to run a taller tire but have to use a limit cable to prevent driveshaft contact at full extension. Looking at your pics, you definitely need to raise the trans some more. Get the engine, trans, and rear end relationship right, then deal with the exhaust. Most likely you will have to modify or remake that front down pipe - it seems to be a problem with pretty much all the various Chevy engine platforms people use.
  22. #139
    May 2018
    Pinckney, MI
    Quote Originally Posted by sread View Post
    Thanks for the feedback. What did you do for a limit cable?
    - Peterh226 #1134
  23. #140
    May 2018
    Pinckney, MI
    Gauges and panel preview
    Cool Dakota Digital gauges.
    - Peterh226 #1134
  24. #141
    Damn those are pretty. I’m very please with the quality and simplicity of the gauges I just installed from them.
    Titled 2-28-20
    MkI.IV 2643k
  25. #142
    Today was install the engine and see if things fit. There are a bunch of things for the interior (seat mounts) and other routing I want to plan. So, this is a test install and I'll probably remove it to do the floors and drill other stuff.
    Attachment 113969
    The front clearance for one of the steering rack mount was going to interfere with the pulley so I ground it down a bit. I'm using a Blueprint 383 which has the March front mounts.
    Attachment 113970 Attachment 113971
    I then created new spacers from galvanized pipe as my hardware store didn't have any stainless tube. I moved the engine back 1/2 inch total.
    Attachment 113973
    Attachment 113974
    I'm using the Flowtech headers and the downpipe attached just fine.
    Attachment 113968
    Looks like it belongs here
    Attachment 113972
    My pal David E and I just dropped a Blueprint 400 SBC into his 33 this past weekend and ran in to the same fitment issue.
    Thanks for posting these extremely important pictures because they really will be helping us a lot as we adjust things this weekend.
  26. #143
    May 2018
    Pinckney, MI
    After playing around with moving the trans mount up and down, I now have it back to where it was originally. I added about 1/2 of spacers at the exhaust flange on the passenger side and I think that will end up making the exhaust for with the new floor.
    There is only about 1/4 inch (8mm???) between the muffler and floor. But that is what the muffler supports work out to be as well.
    I mounted the muffler hangers with 5/16 Riv nuts into the frame.
    - Peterh226 #1134
  27. #144
    Peter,
    We shifted things around last night and were able to gain the necessary clearance.
    Thanks again for the help with the drive-line placement.
    May 2018
    Pinckney, MI
    First time on new wheels and tires
    - Peterh226 #1134
  29. Likes FF33rod, HVACMAN liked this post
  30. #146
    I can’t wait to see it. Moving shop tomorrow to Virginia.
    Titled 2-28-20
    MkI.IV 2643k
  31. #147
    Jun 2018
    North Vancouver, BC, Canada
    Looks great Peter! how big are the rears?
    Gen 1 '33 Hot Rod #1104
  32. #148
    pick up truck tail gate cables - no particular one, just the approximate length wanted - I think it was about 13 inches if I remember right.
  33. #149
    May 2018
    Pinckney, MI
    Finding matching tires was part of the challenge that factored into the selection. Also, I didn't want full R tires, these will be sticky enough!
    - Peterh226 #1134
  34. Likes FF33rod liked this post
  35. #150
    May 2018
    Pinckney, MI
    Rear suspension limit straps
    Here’s the straps I used so the rear doesn’t cause the driveshaft to hit the frame.
    D8517910-D25E-411F-958B-6984D708DE5C.jpeg 7DCC0183-F188-4A0D-8BB1-B41615218458.jpeg
    Fit like it was designed to be there!
    Mastercraft Limit Straps 214004 from Summit - 14" eye to eye
    1" - 1/2-13 Grade 8 hex bolt with nyloc nut
    Drilled out lower existing hole/slot to size.
    - Peterh226 #1134
  36. Likes FF33rod, shmelty, e36m3 liked this post
  37. #151
    I really like the execution because the straps really look like they were designed to be there so Bravo on your solution!
    Thanks for posting these pics because we're seeing similar issues on my pal's 33 as well even though we haven't permanently installed the driveshaft yet.
  38. Thanks e36m3 thanked for this post
  39. #152
    Sep 2015
    Bridgewater, MA
    What Flowtech headers are those? I can only find the 11102's in Black
  40. #153
    May 2018
    Pinckney, MI
    Quote Originally Posted by shmelty View Post
    The black is just temporary paint. I had them coated by a local shop.
    - Peterh226 #1134
  41. #154
    Sep 2015
    Bridgewater, MA
    Thank you sir!
  42. #155
    May 2018
    Pinckney, MI
    Back to body work
    I wanted to check the wheel and tire fit as well as the under dash area. So many interdependent systems. Got the replacement drivers door fitted. This one is close enough that I will be able to get a fit I’m happy with. Decided to also start on the power windows. Completely new approach with the Gen 2.
    I need 1/2” spacers on the rear to prevent contact with the body. Helps fill out the fenders as well. Pictures have wood spacers (really old school!)
    EE558B8B-C4CC-4982-A3C2-B442B14686CF.jpeg. 8EE1667F-53F9-4B4B-988A-0639A177A77D.jpg. EFE62EB9-203F-4279-ABD4-AE5DF23E6E64.jpeg
    Making progress anyway!
  43. #156
    Senior Member JOP33's Avatar
    Haslet, Texas
    Peterh226, your build is looking awesome, you should be extremely proud!
  44. Likes shmelty liked this post
  45. #157
    Feb 2013
    Gen II Power Window AL Trim
    My trim is positioned just like yours. Seems to need some moderate cutting and rewelding to fit. Does anyone have a picture of a completed trim product? David at FFR does not have a picture. The instructions offer limited guidance.
    Thanks for your post..I thought I was alone and messed up my door openings.
  46. #158
    May 2018
    Pinckney, MI
    Quote Originally Posted by JOP33 View Post
    Thanks! It sometimes feels like you take steps backwards as you move along sooooo many small details. As I make progress, it really will be something that I built. Just trying to minimize the mistakes. Thanks for the support. It's really fun to see others (like you) get to the finish line (although I'm not sure it is ever finished!).
    - Peterh226 #1134
  47. #159
    May 2018
    Pinckney, MI
    Quote Originally Posted by BC Huselton View Post
    Not sure about welding... I want to see how the glass ends up being positioned before I commit to anything with these aluminum pieces...
    - Polish the aluminum and clear coat?
    - Fill and finish in body color?
    - Powder coat?
    - Bolt/Glue to attach??
    - How to address the gap between the aluminum and the top of the door. (I did not fill before cutting the slots)
    What is anyone else doing with these Gen 2 changes???
    - Peterh226 #1134
  48. #160
    Kingwood Texas
    I filled the gap on my doors before working with the windows and it seems to work out ok. I did have to remove a small amount of aluminum to get it to work but not much.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  49. Thanks peterh226 thanked for this post
    Likes FF33rod, AJT '33 liked this post
