Results 1 to 8 of 8
Thread: What occupies this space in the engine bay?
    Senior Member beeman's Avatar
    Indiana
    Am I forgetting something that goes here on the driver's side? Or can I fabricate an airbox to put here? Thanks!
    GTM #304 LPE 525hp LS3
    st george, ut
    nothing really goes there. I mounted my fuel pump there. the hood hinge goes on the roll bar
    Indiana
    Cool, thanks!
    On most of the cars we do, we end up mounting the coolant reservoir (the stock 'Vette reservoir or the Canton direct-fit replacment) above the fuel tank there which takes up a good deal of that room......and then we do end up running the cold air intake over there on most cars. On other cars that we run the cold air intake to the passenger side, a lot of times we'll mount the rear Infinitybox powercell there.
    Shane Vacek
    www.vraptorspeedworks.com
    Apr 2019
    for me cold air intake.
    what is the big tube out of you fuel tank?
    Senior Member tanderson1's Avatar
    Nov 2012
    Calgary Alberta Canada
    I put my fuel pump, regulator, controller and fuel filters there also the factory cold air intake (if you bought it) has to snake through there.
    Indiana
    Quote Originally Posted by KGTM View Post
    That's my new fuel filler, sealed up the crossover tube filler location since it kinked against the body and I wanted to move the filler location on the body as well.
    https://thefactoryfiveforum.com/show...l=1#post347062
    LCD Gauges's Avatar
    Toronto, Ontario
    Mine is full of dust and dirt right now.
