Results 1 to 17 of 17
Thread: Reccomendation? Transmission supplier
    Mar 2018
    Saint Johns, Florida
    Question Reccomendation? Transmission supplier
    Hi there,
    Has anyone dealt with Silver Sport Transmissions? The Tremec TKO 600 is not a problem. But how about their clutch and flywheel: Advanced Friction?
    SST has an extended 3 year warranty and they say they leak check each tranny and cut off the unused support on the bottom. If not SST, who would you reccomend for the best price/service?
    I appreciat any suggestions.
    From what I hear, Mike Forte would be a good choice.
    Two of my friends have purchased transmissions from him and have been very pleased.
    http://fortesparts.com/#tremec
    Good Luck From The Dark-Dart Side!
    Jan 2013
    I would agree. A bought my tkom600 from Mike and he cuts the tail shaft and installed a mid shift kit! Enjoy
    Forte without question.
    Jun 2015
    Fairfax Station VA
    Another satisfied Forte customer here. Outstanding tech support; he'll answer his phone pretty much any time you need him. And I LOVE listening to his Boston accent - takes me back to my earliest days in the AF.
    MK IV Roadster #8631
    Lilburn, GA
    I purchased my Coyote, Trans, steel bell housing and clutch directly from Ford Racing.
    Mar 2013
    Fort Collins, Colorado
    Bob Hanlon, aka HanlonMotorsports.com , built my TKO600 with tail shaft mod and a mid shift. I thought that T5's were smooth, but this is by far the easiest manual trans I have ever had.
    EDIT: Pricing will be within a few dollars no matter where you go, due to tremec's protection plan.
    MK2 #3319.... On the road since 2002 with a lot of upgrades
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    I used Forte for my TKO600, Moser rear end, clutch kit, and bell housing. Mike’s got tons of knowledge which he freely shares. I’ve called several times.
    Make sure when you order a bell housing that it matches your fly wheel.....
    Mark4 - 331 Stroker - Fitech 600 -TKO600 - Moser 3.55
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    ditto on Forte. Mike will cut the tail and set you up with flywheel, clutch and bell housing.
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Woodstock ,Illinois
    Forte!
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Forte.
    Kyle
    Another for Forte
    Dec 2017
    Southern Ontario
    I think the Forte's have it...lol
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Apr 2014
    Memphis, TN
    I used silver sport for a bellhousing. Price was actually cheaper on ebay than their own website. I called them and he assured me it was the same people and to just order through ebay. Called back a few minutes later and they had the order and would ship it out later that day. Very helpful and easy to work with, but I was only getting a bellhousing.
    Ryan
    33 Hot Rod
    Mar 2018
    Cool Forte it is!!
    Quote Originally Posted by mlewis View Post
    I just spoke with Mike yesterday; 26 years experience with Tremec. With FFR since inception.
    Order placed!!
    Conesus, NY
    Forte for engine and transmission. You won't go wrong and his customer service of 24/7 365 is unmatched!
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
    On a roll Al_C's Avatar
    Wheaton, IL
    Quote Originally Posted by Jeff's First FFR View Post
    Order placed!!
    Good choice. Another satisfied customer here.
