Results 1 to 6 of 6
Thread: How to tighten the dash switches?
    Junior Member RonJon24's Avatar
    Jul 2017
    Brighton, MI
    I am having a real problem getting the wiper switch nut and the ignition nut tight against the dash. Is there a special tool or technique that I can use? They both seem to have small slots or shapes that would accept some tool, but due to the odd shape I can fathom what tool I would use off the shelf?
    Thanks in Advance
    MkIV Roadster Base Kit ordered #9460, Picked Up on 10/26/2018
    5.0L, T5, 3.73 Ratio 8.8 Rear End...nitrous plate system (shhhh)
    Toyota Engineer looking to turn my college project car, 1988 Ford Mustang GT...flat black...not a nice vehicle, into a awesome machine to tear up the streets, strip, and track!!
    Port Charlotte, FL
    Probably not the best tool for the job but I use channel lock pliers with electrical tape on the jaws and it works every time.
    Henry
    Fairfax Station VA
    Taped up channel locks for the front, and then a bicycle wrench (it's super thin) for the back. Hold the front, tighten the back.
    MK IV Roadster #8631
    Jul 2017
    Brighton, MI
    Thanks guys! I’ll give that a shot.
    Southport, NC
    Yes there is a special tool.
    However, it's easy to make. Find a metal tube that is the same diameter as the bezel nut. Cut away metal from the end leaving only two nibs that will fit into the recesses of the bezel. You'll always have that tool for future work on those switches.
    George
    Raleigh NC, OIB NC
    Used a very small screwdriver blade to push them around.
    Kevin
    MKIV #8234
