Likes Likes:  4
Results 1 to 19 of 19
Thread: First Start
    Oct 2017
    First Start
    There was 20-30 Seconds of cranking priour to this to clear the air out of the fuel rails
    https://www.youtube.com/watch?v=Dyw15Jv9DkI
    MK4 #9191, Gen 3 Coyote, T56, 2015+ IRS, ABS, 12.88 Wilwood's, FFR Tubular Front LCA's, FFR Spindles
  2. Likes FF33rod, Straversi, Drezx6r, MVRight liked this post
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Congratulations! That's a huge milestone.
    Elk Grove, NorCal
    Congratulations.
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Looks and sounds great. Congratulations. No sure how many Gen 3 Coyotes there are out there. Mine cranked a bit on the first start as well. You're brave running that thing with open exhaust. I ran mine once like that to move it, and don't plan to again. Other than being crazy loud, you'll find it runs better with the pipes. I suspect because of some back pressure and maybe mostly because the O2 sensors don't get a good signal right next to that open end.
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Congrats! I agree about starting her without pipes, ear damage happens quickly.
    Kyle
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Congratulations.
    Sounds like it's good to go. Congratulations!
    Things to check while it's running are Oil Pressure and if your Alternator is charging, either with an Amp meter or the rise in voltage to over 14vdc. Just a short run is not long enough for the ECU to learn anything, but it will register if sensors aren't working and throw "P" codes. Once it's warmed up and the Coolant has had a chance to get hot, you can check for coolant and oil leaks. I think one reason people "Go Cart", otherwise it's good for testing car alarms in your neighborhood!
    A Big Congratulations From The Dark Side!
  10. #9
    congrats!! I like what you did with the air intake. Have not really seen that setup before. Do you plan to do anything additional on the body to feed air to it?
  11. #10
    mburger's Avatar
    Punta Gorda FL
    Congrats! Sounds good!
    Hopefully you were wearing ear plugs. Those decibels are enough to cause permanent hearing loss. Take it from someone that wears two hearing aids to hear anything. Once your hearing is gone, you don’t get it back.
    Mark
  12. #11
    Conesus, NY
    Congrats. Ran mine with out pipes too. I don't hear any worse than I did before I ran it. LOL
    Chuck Krueger
    MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
  13. #12
    cv2065's Avatar
    Dec 2017
    Congrats on the first start!! Pipes only take about 15-20 minutes to install. Save your hearing!
  14. #13
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Awesome.
    Congrat's !!
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
  15. #14
    Oct 2017
    Thanks. You may be right that the back pressure helps. i did note that after it warned up a bit if i blipped the throttle it would idle much quieter and smoother for a little bit.
  16. #15
    Oct 2017
    Quote Originally Posted by Megascott View Post
    Thanks. all of the gauges were working correctly. started it several times and the last time let it idle until the cooling fan came on
  17. #16
    Oct 2017
    Nope. It will just take suction from the wheel well.
  18. #17
    Oct 2017
    They will be on next time, which should be the first go cart.
  19. #18
    Nov 2018
    Centennial, CO
    Congrats on first start. I’ve been thinking of doing the same thing on the intake air. Have you done any research on the temperature drop from engine bay to wheel well? I haven’t done the upper radiator cowl because I’m thinking the engine bay would flow cooler air without it...probably not. Is that a kit or your own design?
    Bradley
  20. #19
    Oct 2018
    Congrats!!! that is Awesome. Hoping to give mine a try this weekend
    Nick
