Also consider the power draw of your fuel pump. One argument for bypassing the RF harness and running the Holley Sniper fuel pump blue wire all the way to the fuel pump is that the Holley Sniper fuel pump wire is 14AWG whereas the RF wire is 18 AWG.
I ran the the Holley Sniper blue wire into the cockpit through one of the firewall holes, and then back out to the rear of the car via the rear harness. I added a weatherpack connector behind the dash at this point so that I could disconnect the fuel pump there, which came in handy when I powered up the car but didn't want the fuel pump running. I removed the RF fuel pump relay from the fuse panel, and repurposed the original RF fuel pump wire in the rear harness as a trunk light power wire.
