Results 1 to 9 of 9
Thread: under coating the fiberglass body
    May 2018
    Has anyone undercoated the fiberglass body of the MK4 before assembly. If so, what product do you recommend
    Quote Originally Posted by Jordan Law View Post
    Herculiner or UPOL Raptor are both good choices.
    https://youtu.be/b1fcntE6Ryc
    Just Wear Gloves!
    On a roll Al_C's Avatar
    Wheaton, IL
    check this thread: https://thefactoryfiveforum.com/show...ndation-please!
    I recommend the Dupli-color. I used it and am happy with the results. Big plus: clean up is easy.
    BadAsp427's Avatar
    Greeneville, TN
    There are many build threads on here with many different options for this. Here is a LINK to my build thread page where I did mine.
    May 2018
    Just Wear Gloves!
    Thanks so much for the input
    May 2018
    Thanks so much and the link was/is great \.
    I first painted the entire underside with black epoxy paint. After completion, but before final body paint, I brushed the area of the body above the tires, with a bed-liner. Then as a final sealer/protectant, in the tire areas of the body, and rear cockpit exterior cockpit aluminum, I sprayed a rubberized/ashphalt undercoating. Also did all four aluminum splash shields. The idea being, it would reduce road noise from debris kicked up by the tires, and further prevent stars in the paint.
    Conesus, NY
    I undercoated and also did Alex's inner wheel well liners as I was still concerned about stone hits reflecting up through the fender to the paint. Plus the liners give a more finished look.
    Chuck Krueger
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
    Raleigh NC, OIB NC
    Was one of those things that slipped my mind till it was painted. I put in wheel well liners instead. All alloy exposed exposed to the weather is covered with truck bed liner
    Kevin
    MKIV #8234
