Likes Likes:  2
Results 1 to 3 of 3
Thread: Third brake light
    herb fraser's Avatar
    Third brake light
    what do you think?
    just made this third brake light
    pretty simple. purchased LED strip
    used red plexi
    It is flush with the body
  2. Likes billjr212, FF33rod liked this post
    Frankfort, IL
    I like it. Looks good. is it installed in a way that you can easily swap out the led in the event of failure? I know LED's typically last virtually forever, but they do occasionally fail. Assuming it is reasonably priced, might not be a bad idea to buy another identical light in case it fails a few years down the road and that specific version is no longer available.
    yep I can change it form inside the cab, and yes I have a few of them
