I am in the go kart stage. My brother noticed while I'm doing hard accellerations or hard left turns fuel is dumping out around the filler neck gasket. Like a lot of fuel. I installed the tank and fuel filler neck back in December and it has been manipulated quit a bit, I didn't zip tie it in place or anything. The filler neck does seem a little loose in the gasket. I am quit sure that I followed the instructions correctly. Here are some photos.
I'm thinking maybe I should just replace the gasket. I can't imagine that its gone bad just sitting there. I also doubt I damaged it at install, was pretty simple to install and inspect. Maybe just hanging there and getting manipulated or jostled from time to time has loosened it up?
Mark,
When I mounted the body for the final time, I noticed my tank was leaking from the fill pipe gasket. When I took the fill pipe out to inspect, the gasket was torn. Just the fill pipe moving around during my go cart stage damaged the gasket. The Ford OEM part number is #F4ZZ-9072-DA. It is a better gasket than the one that comes with the kit.
X2 on the genuine F4ZZ-9072-DA Ford part. Breeze has them. So does Amazon (of course) plus others. Just hold out for the genuine Ford part. Put a little lube on the filler tube when installing and do something to tie it down in the right position until you get the body on. Otherwise you might get to replace it again.
Build 1: Mk3 Roadster #5125. Sold 11/08/2014. Build 2: Mk4 Roadster #7750. Sold 04/10/2017. Build Thread Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 Coyote. Legal 03/04/2020. Build Thread and Video Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Legal 04/20/2023. Build Thread. Sold 11/9/2023.
As has been noted, replace with a Ford part. When you install it, use engine oil as the lube and check to make sure the hold down isn't putting pressure on the fill tube pulling off center.
Something to consider for later on is the alignment of the fill tube and the body. My fill tube when aligned with the body cutout, was twisted and kinked somewhat in the tank and gasket, and was binding. To get the tube to align with the body correctly, and have the fill tube in the tank and gasket with no binding, I lengthened the tube on the tank end. (if I remember right it was about an inch and a half, maybe a bit more.).
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
After reading this thread I checked the FFR gasket on my fill pipe and sure enough it was torn/cut about half way thru. I just finished installing the new Ford gasket. Much better now.
JR
I was part of this club last year on the power tour. Easy fix in a hotel parking lot We could smell gas when we filled up, and crawled under the car to find the gasket torn. We ran the car until it was very low in gas, then did swap in the parking lot that particular evening.
Videos are at: YouTube Videos
