You are correct the Sniper unit has the pump running all the time. That is the reason for the return line. I completely removed the Holley blue pump wire. I am using the RF harness with the inertia switch. Sniper unit runs great without it. Why complicate wiring with adding additional wiring? All you are doing is creating additional potential failure points. I learned long ago (KISS) Keep it simple stupid.
