0
Holley Sniper Fuel Pump Wiring
I asked the question here, but I didn't get an answer:
https://thefactoryfiveforum.com/show...inertia-switch
So I'm trying to run the wiring for the fuel pump. I'm using the RF harness with the fuel pump in the tank. I want to keep the relay, fuse and inertia switch. So do I cut the jumper in the fuse panel as shown in the wiring manual and then connect the blue wire from the sniper to that wire that I cut?
Thanks for the help, wiring is not my best area.
