0
0
818 fuel tank pump and sensor
I replaced the old gas tank with the new tank for 818 # 107. The original old tank used 2 small round inserts that came with the kit. The new tank uses the original Subaru WRX oval pump insert and larger round fuel sensor. Any 818R folks using a fuel cell have them lying around?
Found one. Needed a new rubber gasket, $ 10.00.
- You may not post replies
- You may not edit your posts
Forum Rules
