Thanks Thanks:  2
Likes Likes:  3
Results 1 to 3 of 3
Thread: Holley Sniper install
    Gorham, ME
    Most of you are probably aware of the issues I had with the Fast EZ EFI system on my coupe. I sold it and purchased a Holley Sniper EFI on recommendation of Mark Dougherty. I installed it and the engine started right up. Install was simple too. Hot and neutral on the battery, one lead to the inginition switch, and one to the negative of the coil. I also tied in the fan control but that is optional. My timing is controlled through the distributor but you can also have the control module take care of it.
    The only problem I ran into was that the engine backfired through the top end. After talking to Mark we concluded that it may be a valve that is not set properly.
    Learned about setting valve lash. Failed twice but the third method from YouTube got it going right.
    I also bought a male female an fitting to put in a pressure gauge.
    Then I had a non functioning fan to deal with which turned out to be the 12V positive not being tied in. Easy fix and I was rumbling down my street for the first time in a long time. Have to drive it more for the self tuning function to start picking up driving habits, but so far so good.
  2. Likes mburger liked this post
    Good call retaining the FAST throttle linkage bracket! I tried a couple of others and found that one to work best.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  4. Thanks John Dol thanked for this post
    Likes John Dol liked this post
  5. #3
    Top Notch Builder P100DHG's Avatar
    Pasadena, CA
    I’m glad to see you got this sorted out. I have FAST EFI in my Roush engine being delivered next month. It was fully setup by them so I am hoping for great results but if it’s a fail I’m glad there is a good backup. Thanks for the R&D and sorry about your frustrations.
  6. Thanks John Dol thanked for this post
