0
Questions on body fitment to determine dash and seat locations
Hi Guys,
I am getting close to dropping my body back on the frame to determine the proper location for my dash and dash fasteners. What all do I need to install to get the body in the correct location? I assume the foam or bulb seal that goes over the dash hoop? Do I need to put the foam on that runs down the engine compartment rails or in the trunk area? How about the body bolts in the front and back or the screws on the sides? Is there anything else I'm missing.
While I'm at it, I figured it would be a great time to locate the seats. Do you have any pointers for locating the seats properly? I have the standard low back FFR seats and some sliders that I got from Summit. I assume I'll want to put on the doors? Do I need to worry about clearance for the emergency brake lever? Is there anything else I should be concerned with?
Any advice is greatly appreciated.
Serial #9158
