Thanks Thanks:  3
Likes Likes:  6
Results 1 to 33 of 33
Thread: New style adjustable headers.
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    My 302 headers arrived today. It looks like FF is sending out the new style headers that are on the 25th anniversary kit. Plus they already have O2 bungs in the collector. Very pleasant surprise!
    Terry
    They've been shipping for a few months.
    Milton,DE
    That looks like a very nice product improvement!
    Olli
    Jun 2017
    Norway
    I checked with FFR the first thing I saw these. Very happy that they confirmed I'll be receiving these with the kit, which by the way must be somewhere in the Atlantic right now.
    Now consider grabbing some Adjustment Wedges from Mark Reynolds at Breeze Automotive and all will be right with the world.
    https://www.breezeautomotive.com/?s=...t_type=product
    Between the new headers and some adjustment wedges you should be able to really nail the pipe location with little difficulty.
    Bourne-Cape Cod, MA
    The whole point of the new pipes is to eliminate the need for the wedges.
    FFinisher/AKA RE63
    Quote Originally Posted by FFinisher View Post
    No Excrement Dick Tracy; however, we all know that getting the angle of the dangle spot on perfect may need a little extra help unless you fab up your own headers like some of us did. ..Heck, some of us (Meaning Me) are so OCD that we (Me) even shortened the wheelbase to center the rear wheels since Factory Five didn't.
    Look Mom, Centered Rear Wheels & Nicely Hung Pipes On Custom IMCA Headers!
    https://youtu.be/CaRlqMmKIzk
  8. Likes nucjd19 liked this post
  9. #8
    Bourne-Cape Cod, MA
    No need for insults, although it seems the American way these days. I was posting to help others
    FFinisher/AKA RE63
  10. #9
    Jun 2019
    Las Vegas, NV
    FFinisher Your post was helpful for me. Thanks.
    Terry
  11. Thanks luvaz thanked for this post
    Likes luvaz liked this post
  12. #10
    My reply was not an insult, but I must admit that Southern Humor & Sarcasm are often misunderstood.
    Sorry I Offended You!
  13. Likes rezell3d, nucjd19 liked this post
  14. #11
    Adjustment is nice if it stays adusted. J-tube ball joint does not stay in place. The headers has 3 bolts vs 2. It should help.
    If not, it would be easy to tack weld in place.
  15. #12
    Dec 2013
    Sandia Park, NM
    Are these only for the Coyote or are they for all 302's? They don't seem to be under the Parts tab on the FFR website.
  16. #13
    RBachman's Avatar
    Jul 2019
    ..........we (Me) even shortened the wheelbase to center the rear wheels since Factory Five didn't.
    My kit arrives later this month and off-center rear wheels has been a nagging thought. It seems this has been a long time issue and that it wouldn't take much to change/correct. Why hasn't it been done? There must be a good reason?
    FFR MKIV ordered 12 July 2019. IRS, Wilwood Brakes, 18" Wheels w/MT tires, power steering, EFI, Heat. 347 Dart w/TKO-600 by Mike Forte, Holley FI, MSD coil and CD box. All new, no donor build.
  17. #14
    Jun 2019
    Las Vegas, NV
    Quote Originally Posted by swwebb View Post
    I ordered the "standard" 4 into 4 302 headers when I ordered my car. These are what arrived. I think that they are FFR's replacement. They don't look as clean as the standard headers, but for functionality, they are great.
  18. #15
    Woodstock ,Illinois
    I do admit that they looked “busy” the first time I saw them. But the function ability can’t be denied! I’d probably set them up and get them tig welded before cutting off the collars.
  19. #16
    Quote Originally Posted by RBachman View Post
    From what I understand the 25th anniversary cars will be using All New Molds that addresses the off-center rear wheel issue among other problems.
    Hopefully those molds will be used for all future MK-4's after all of the 25th Anniversary Special Addition Cars are sold.
    Since I don't have the IRS set up so I don't know how much things can be adjusted to minimize the issue.
  20. Thanks RBachman thanked for this post
    Likes RBachman liked this post
  21. #17
    Based on the 20th anniversary video Dave Smith did, the "new" bodies will be sold for all new kits going forward. Don't know the exact cut-in date. You could ask if yours will be one. Good to see they tucked in the openings a bit. But off-center isn't necessarily the case for all. Gets a lot of discussion I guess, but I personally haven't seen in with my builds. I see you have IRS, and my 20th with IRS is fine.
  22. Thanks RBachman thanked for this post
  23. #18
    Senior Member 289FIA_Cobra's Avatar
    Sunnyvale, CA
    Quote Originally Posted by TMartinLVNV View Post
    Terry
    Are these available to order from FFR (just these new headers)? I have an older MKIII and going EFI this winter.
    Might be time to call them.
    https://hhong43.wixsite.com/snkvnnm-build
    FFR #4883: 347CID|CompCam Magnum 286HR|Vic. Jr. heads|Hurricane Intake | Mighty Demon 650DP|IRS w/Torsen T2 & 3.55 | MSD ignition system | Mallory pump/filter/reg.|Forgestar CF5 18" w/245-45R18 & 295-35R18|Original I-Squared 1+1 System ☺ ☺☺
  24. #19
    Kirkland, WA
    I bought a new set of these headers for Coyote last month - they're not on the website, just email or call.
  25. #20
    Feb 2018
    How was that an insult? Sensitive are we?
    All he was saying .. he agreed to what you said but you're still going to need to do an adjustment unless you fabricated them yourself to your chassis and engine combo.
    It's just guys being guys.
  26. #21
    Feb 2020
    Will these header fit and working with a SBF 363 with high port heads. (Exhaust Ports raised .750" over stock)? T
    Thank you
  27. #22
    Nov 2019
    Charlotte, NC
    For what it’s worth, my sidepipes aligned perfectly using the ball headers with no wedges needed. Also, I got my kit back in January and it came from the new molds. Several needed enhancements that are detailed in one of the 25th anny videos from Dave Smith.
  28. #23
    Mar 2017
    Lafayette, CA
    I have these headers and have noticed the side pipes sagging a bit despite the collars being very tight. It was mentioned above that you can tack weld them to prevent the sagging.
    Has anyone tried this? Does it work?
    MK4 Roadster #9138
    Blueprint 427 with Sniper EFI, TKO600, IRS, complete kit
    https://thefactoryfiveforum.com/show...8-Build-Thread
  29. #24
    Nov 2019
    Charlotte, NC
    Do you have the rear support brackets installed?
  30. #25
    Jun 2019
    Las Vegas, NV
    Sagging has not been a problem for me. I had to tighten up the bolts at the collars on each side after putting some miles on the car and have not had to touch them since. The rear mount is what seems to hold the exhaust up. The inner solid mount bolt broke on each side and mine are being held up by the rubber hanger only and seem to be doing fine. I guess if I had to do it over, I would not have even used the inner solid mount.
  31. #26
    Mar 2017
    Lafayette, CA
    Quote Originally Posted by BradCraig View Post
    Great point! No, I’m still in go kart and have some temporary rear support straps, but don’t have the brackets installed yet. Hopefully they will work when I install them after the painted body goes back on. Thanks.
  32. #27
    My 2cents. As far as aligning the side pipes...they help. You will ALWAYS need to modify the cut out to some degree. I have worked with 6 cars so far and had to move the cut out on 3 of them enough to have to reglass to backfill. The ball joint gives you a lot but not everything. With the under car pipe bracket in place the sidepipe will still sag after vibration and heat cycle. I would suggest (once they are where you want them) (relative to the body not the chassis) to have them welded up so they don't move turning them into a regular o'l header...da Bat
  33. #28
    Accord NY
    Can someone confirm that the Coyote headers sold by factory five now have the new flange and collars that are adjustable?
  34. #29
    O'Fallon, MO
    See post #19
    Mrk III, 331 stroker, Borla stack injection, T5, 3:55 IRS, Power steering and brakes. Kleiner body & paint
  35. #30
    Accord NY
    Thanks Rich.
  36. #31
    O'Fallon, MO
    Thats the only style of header that Factory Five now sells. Just look at their parts site.
  37. #32
    Accord NY
    I did look at the parts site and for the coyote they only show it without the connector. Thanks again for filling me in.
  38. #33
    Bought some of these new headers (302) for my Gen III coupe from the FFR web page.
    Fit and alignment is great and no more need for sandwiches of wedges and gaskets.
    Lighter (stainless steel) than the old ones by a few lbs.
    Mine do sag at the ball couplers- the bolts are not fully threaded and the nuts are the end of the threads and can't be tightened any further- just need to get some washers under the bolt heads.
    Gen III Coupe #17
