Likes Likes:  2
Results 1 to 24 of 24
Thread: Bob the builder: Coyote installed
    Sep 2014
    Orange County, Ca
    Kids on our street gave me the above name because I was always working in the garage.
    I first posted on the Roadster page as “ I’m joining the club” Figured I should move over here and do some updates.
    Kit was ready to ship July 27th, she was delivered two weeks later on August 8th.
    My configuration is , IRS, powder coated, cut outs, Coyote, leather seats. blank dash, Power steering, heater, 17” halibrands, sun visors and wind wings.
    Front suspension installed and rack centered per Karlos. I need to remove the shocks and check the rebound damping. All rivet holes drilled for front sheet metal.
    Optional jungle gym for grand kids
    IRS installed, waiting for back ordered calipers. That pumpkin is heavy and awkward.
    I was never warned by forum members on how many band aids I would need.
    As she sits today.
    Edmonton Alberta
    check your upper "A" arm to hub bolts on the IRS, I think you have the spacer on the wrong side.
    David W
    Mkll 4874 built in 2004
    Sep 2014
    Orange County, Ca
    Is this wrong?
    Sep 2014
    Orange County, Ca
    Mocked up the Russ Thompson drop trunk today. The instructions are clear and I’m very happy with the quality of his products.
    Matting corners are marked with matching alpha charters making it easy for dummies (me) to not goof it up.
    All mocked up, I had to do a second cut around the entire perimeter of the drop trunk to make the transition between the vertical trunk wall and existing trunk deck match better.
    Sep 2014
    Orange County, Ca
    Ordered my Gen 2 Coyote, TKO 600, scatter shield, hydraulic clutch, SS headers with cats, drive shaft safety loop and heated seat inserts from Mike Forte today. It sound like the Gen 2’s are getting harder and harder to find. Mike is a great guy to work with.
    I also dropped off my engine compartment panels for powder coating yesterday.
    Sep 2014
    Orange County, Ca
    I had my engine compartment powder coated the wrong color. I wanted a gun metal gray in came out a dark gray with a green tone. I think my path forward will be scuff up the panels and paint with a rattle can, a little depressed, oh well, push forward. Yes, it was me that picked the wrong color.
    Senior Member MSumners's Avatar
    Dec 2018
    Hudsonville, MI
    Quote Originally Posted by bobm488 View Post
    Is this wrong?
    Can’t completely tell from the picture but seems ok, others should chime in. This is what mine looked like. Thread spacing should be approximately equal at the stated arm length for adjustability later as well.
    Complete kit. Delivered 3/19.
    Build thread: https://thefactoryfiveforum.com/show...4-Build-Thread
    Dart 347 with FiTech 600 from Forte. TKO600. PS. IRS. Wilwoods.
    Forte hydraulic clutch, mech throttle.
    Multiple breeze components: RT turn signal and drop trunk.
    ReplicaParts: Radiator aluminum, under dash panel, multiple different trim rings.
    Mark Eaton's Avatar
    Oregon
    Is this wrong?
    That looks like the way I did mine, which doesn't necessarily mean its correct, lol. But what do you mean by "wrong"?
    MK4 #9130 , complete kit, arrived 8/10/2017.
    Sep 2014
    Orange County, Ca
    Quote Originally Posted by Mark Eaton View Post
    David Williamson said.
    "check your upper "A" arm to hub bolts on the IRS, I think you have the spacer on the wrong side.
    David W"
    Mark Eaton's Avatar
    Oregon
    The photo you showed is the upper control arm to spindle and the spacer looks correct to me.
    Sep 2014
    Orange County, Ca
    A few progress photos.
    Installed a triple reservoir, this thing is massive.
    Bracket made from old piece of angle
    Fabricated upper side panels for the trunk, easier and a lot messier than I thought. I traced the outside trunk panel onto a piece of aluminum, then added three tabs that would later be bent to sit on top of the trunk steel. After getting the shape, there was a lot of trimming and test fitting to miss the seat belt bracket and roll bar.
    Jun 2019
    Las Vegas, NV
    Hey Bob. The upper trunk panels look great!
    MK IV Build #9659, 3 link, 17's, Forte 347, Sniper EFI, power steering, built for a freak sized person with 17" Kirkey Vintage seats, RT drop trunk, RT turn signal, lots of stuff from Breeze Automotive, Wilwood brakes
    Nov 2018
    Looking good! good luck with the rest of the build!
    Sep 2014
    Orange County, Ca
    Coyote showed up from Forte the other day, it’s huge. Now the hard work begins.
  15. Likes Straversi liked this post
  16. #15
    Jun 2019
    Las Vegas, NV
    Looking good Bob. Not the hard work. The fun work!
  17. #16
    Bakersfield, Ca.
    That Gen 2 sure looks better than the Gen 3!
  18. #17
    Nov 2012
    Coyote will be awsome in that car. Keep it going.
  19. #18
    Vero Beach FL
    Sweet new stuff. Looking forward to the coyote gen2 install.
  20. #19
    Sep 2014
    Orange County, Ca
    Coyote went in pretty easy. Unfortunately I broke the driver side exhaust gasket. Of course not even Ford keeps them in stock. Engine is sitting on the mounts but not tightened down. I don’t think I should do anything else on the motor until I know I can bolt the header in without having to jack the motor up or move forward to secure all the header bolts. Sorry for the rotated photos.
  21. Likes Straversi liked this post
  22. #20
    Jun 2019
    Las Vegas, NV
    Congrats Bob! Big day for you. Your build is looking good.
  23. #21
    Heart of Dixie, Alabama
    May be something you want to do, or not. I think Jeff K sometimes puts a washer between the engine block and drivers side motor mount. This adds some clearance in the tight areas, ie foot box, valve cover, headers, etc.
    I just did this after the engine and headers are on. Might be easier now for you, if desired.
    It also makes the dipstick a little more accessible.
    One other thing, I have the same reservoirs, not mounted yet. I put the F5 supplied ones on.
    Now I have to change out. It looks like with the reservoirs at the rear most position, the dip stick will be almost inaccessible. I have my body on and installing hood hinges, so should be able to check clearances.
  24. #22
    Sep 2014
    Orange County, Ca
    Thanks Railroad, I escaped my decorating duties for a few minutes to visit garage to investigate the reservoir/dipstick situation. I re-installed the reservoirs and it is definably not optimal, but it does work.
    One washer/shim will make difference on the engine mount?
  25. #23
    I put one average thickness flat washer at each bolt, between the block and motor mount. I can now slide a piece of cardboard between the foot box and all close points on the engine and headers. It is more clearance than I had and put the engine on a perfect level.
    The washer location will not compromise the motor mount. If you want to maintain surface contact area, get a fender washer.
    Check with Jeff Kleiner. It is one of his revealed tricks.
  26. #24
    Sep 2014
    Orange County, Ca
    I'll add them tomorrow, thank you
Racing Adventures
