Rear End Aluminum Alignment
I'm done with the rear end aluminum and there is a significant (maybe 1/2") where the bottom lip of the lower trunk floor panel extends rearward past the side panels on the trunk. Is this normal? Does it need to be trimmed? All panels seem to be properly positioned.
Thanks!
- Jason
edwardb
You don't want/need the standard kit clutch switch with the Coyote. The control pack comes with a different switch that plugs into the control pack harness. It's installed up on the pedal box on the modified clutch quadrant if you're using the Factory Five modified cable setup. Factory Five supplies the necessary mounting pieces on their Coyote completion kit. If you're doing a hydraulic clutch, the pieces can be modified to still work. Several build threads including mine show some ways to do that.
Yes, I've had to trim a little along the transmission tunnel. But not quite that much. Make sure you have the floor sheeting flat on the frame and everything else fitted before cutting anything.
Thanks. I'll ditch that switch and get the other installed. And, yes - I made sure all panels were well seated before trimming.
Thanks again!
Jason
cv2065
I had to trim my tunnel sides just slightly to get them flush. I don't recall trimming any other panels. I'd check and double check fitment before trimming. On the calipers, I had the same issue with paint. Just take care when bleeding, as the bleeder screws can be loose in those calipers and let fluid out that will ruin your paint job. I just ended up not painting the bleeder pad.
Thanks. I probably fitted all panels 5 times to make sure positioning was proper before trimming. Now that they are trimmed, everything seems well aligned.
Thanks again,
- Jason
Traveller
I love roasted peanuts, baked pecans and toasted almonds, but how do roasted coupler nuts taste?
Looking Good & Love The Ingenuity!
Front Battery Tray
I installed the Breeze front mount battery tray. Very nice piece with excellent instructions.
Headers and Pipes Ordered
I've held off ordering my headers and side pipes until now, but given the 4-6 week lead time and my hope that I will make good progress over the next month or two, I contacted Georgie at Gas-N and ordered the headers in natural stainless and the side pipes in polished finish. Can't wait to receive these.
GoDadGo
Tasty, but careful to not chip a tooth...
Traveller
Looking good. I had read in several builds that it was worthwhile to replace the gasket between fuel tank and filler neck that comes with the kit with an OEM gasket from Ford. That proved to be good advice since the kit gasket started leaking right away and I had the OEM gasket on hand. Ford Part # F4ZZ-9072-DA
Straversi
Steve - thank you for the suggestion. I too stumbled across that recommendation and ordered and installed the Ford OEM part. Trying to learn from others experiences as much as I can...
Traveller
Moving on, I finished up the pedal box and started installing the coyote throttle pedal. After trimming according to the instructions, I found the steering shaft was hitting and preventing the pedal from mounting correctly. I saw other posts where this is fairly common, so I had to do some aggressive trimming around the mounting ears (especially the top one) to make it fit.
I saw a post by Hacksaw84 where he made a new pedal pad which matched the other Wilwood pads and I liked it better than the OEM pad (shown in the first pic below).
Here is the
link to Hacksaw's original mod.
I ordered two Wilwood pads off Amazon, trimmed them and mounted them to the coyote pedal arm. I am happy with the results.
Looking good man, appreciate the shout out. I did end up trimming the corner a little after the panel was on. Just to be sure I had complete clearance.
Michael
