Results 1 to 10 of 10
Thread: E Brake cable problems
    Nov 2018
    Scurry Texas
    So I was waiting quite a while on back ordered calipers. Got them a couple weeks ago and installed. E brake cables were wrong so they sent new ones. Got those today and went to install. The passenger side fits great but the drivers side is same length and is tight from handle to caliper. I would not be able to strap it down due to required suspension travel. Is this what everyone else has? Seems like drivers side should be 6-10 inches longer due to e brake handle position?
    Jun 2019
    Whitehouse TX
    I will have to measure mine. I cannot remember if mine are different or not.
    Nov 2018
    Scurry Texas
    Quote Originally Posted by sperger72 View Post
    Is your drivers side tight? Mine is like a banjo string from Caliper to brake handle.
    Jun 2019
    Whitehouse TX
    Mine is not tight at all has crap loads of extra on both sides.
    Zach
    Nov 2018
    Scurry Texas
    Can anyone take a measurement on the e brake cable? FFR is saying that the one I have is correct. Mine measures 67" from end of fitting to end of fitting. 5" of cable sticking out. I cant see how that is correct. It is tight from caliper to brake handle with zero slack.
    Aug 2018
    Hampshire, IL
    I installed a e stopp. Electric gizmo I didn’t want to deal with the hand brake design .
    Nov 2018
    Scurry Texas
    Quote Originally Posted by Robodent View Post
    Sounds like a great idea. I'll check it out.
    Gatineau, Quebec, canada
    If you can provide pictures on how it was installed that would be helpful. TY!
    Andreas
    Aug 2018
    Hampshire, IL
    DC8810E4-A918-4DA5-A7FE-28E94F8A4F16.jpg. I had to fab a bracket to mount it to and the only logical spot was next to the trans on the passenger side
  10. Thanks AJT '33 thanked for this post
  11. #10
    Nov 2018
    Scurry Texas
    Got email back from FFR. They sent wrong length again. Sending more. Third times a charm! I Hope
