Thanks Thanks:  7
Likes Likes:  32
Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
Thread: Mk4 Roadster Build Video: Body Work
    These Videos came out just in time for me. Sure I had already read up on the forums about the idiosyncrasies of the MkIV body and especially the dirty little secrets from Jeff Kleiner on how to get the drivers side door lined up and the trunklid lower section using the Jack studs.
    After making sure the Body was in place and the windscreen was installed, I adjusted the doors Trunk and hood to be evenly centered in the opening as close as possible and adjusted as flush with the body as possible (all at the same time). I used a 3/16 wide black marker and went over the edges of each panel, removed the panel, then trimmed the black line off using my battery powered 4" angle grinder with a 220grit "flap disk" oh boy, does it take off the edge fast. A light touch is all that is needed using this method. Anyway, get the gaps roughed in and the front edge of the doors, hood and trunk lid beveled inwards. I sanded the gaps straight by hand with some 220 grit sandpaper wrapped around a paint stick. I'm pretty happy about it now. of course this is just the beginning. lots more sanding to do and filler to spread...repeat.
    Now where are those video's from FFR about adjusting the hood and trunklid?
    Feb 2020
    i watched a couple of these as well
    and they are quite informative
    iowa
    Here is a better solution that truly fixes the driver's side door.
    https://youtu.be/6UK6K2jcwTU
    Hope this helps everyone.
  4. Thanks Ponymedic thanked for this post
    Likes Ponymedic liked this post
  5. #44
    RJD's Avatar
    Northern Virginia
    Interesting solution. Thanks for sharing.
  6. Thanks GoDadGo thanked for this post
  7. #45
    Webmaster, FFR
    Middleboro, MA
    Sorry for being away from getting the next video posted, but here it is! Tony and John work on trimming the rear wheel well and fitting the trunk. They also discuss some tips on fitting the Aston LeMans gas cap and tail lights.
    Dave Lindsey
    FFR's Mad Dog
  8. #46
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Good to see another video, thanks Dave. By the way what is a truck?
    JR
  9. #47
    Thanks For Posting This New Video!
  10. #48
    These have been great videos. Thanks for taking the time to put them out.
  11. #49
    Factory Five Just Published This Video Today:
    https://youtu.be/qrjs9jeAS9w
  12. #50
    Webmaster, FFR
    Middleboro, MA
    Tony and John fit the hood on the Mk4 Roadster, and give you tips on how to make the hood scoop cut-out. Tony also gives some tips on trimming the inner edge of the cockpit for the dashboard and rear cockpit aluminum.
    Dave Lindsey
    FFR's Mad Dog
  13. Thanks Kmcallahan thanked for this post
    Likes Kmcallahan liked this post
  14. #51
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    I watched pt 1-5 and this is very helpful. At this time I am fitting my doors, hood and trunk. These are awesome.
