Results 1 to 7 of 7
Thread: Transmission Temperature Sensor Addition
    Senior Member Blwalker105's Avatar
    I'm in the process of integrating a quad set of SpeedHut gauges around my instrument cluster (kudos to Mechie3) and am interested in knowing if anyone has added a transmission temperature sensor to the factory 5-speed tranny, and if so, where? I am thinking of drilling and tapping a suitable location about 4"-5" behind the passenger-side axle outlet in an empty 2"-3" aluminum quadrant. Any better ideas?
    Syracuse, NY
    Yes, use the drain plug!
    Check out my build thread here for the details.
    MK3.1 Roadster completed 2011
    Thanks, Hobby Racer!
    Jan 2019
    I was thinking of welding a bung on right next to the drain plug. But I have the 6 speed. It has a little like oil pan.
    Jan 2019
    Edmonton, Alberta
    Very curious as to how hot it gets. Mine was hot to the touch after a 20 minute ride on the highway, but that’s not telling me much. I expect they run quite hot on track for sure. I have an in-line thermo-switch I’m going to use with a cooler on mine.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Syracuse, NY
    I'm swapping over to a 6 speed this winter and doing the same. A thermal bypass valve to the external cooler. Bypasses the cooler when the temp is below 180F and opens the circuit to the cooler when the temp gets over 180F. It also makes it super easy to put in a temp sensor when you have an external cooler.
    When I recorded temps on my 5 speed before I added the external cooler it was quite hot, in excess of 280F after a long track session.
