Thanks Thanks:  2
Likes Likes:  9
Results 1 to 12 of 12
Thread: radiator alignment
    Oct 2019
    radiator alignment
    Book says 5/8 off-center? any reason why not centered?
    That's a leftover from the donor radiator days. If you have a new kit supplied radiator, it can be centered.
  3. Thanks RBachman thanked for this post
    Likes RBachman, FlyFactoryFive liked this post
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I didn't know about the "hold-out from donor days" and installed mine with the offset (Coyote power) in #9365. Having it offset actually helped with needed clearance for the drain petcock, so consider it...
    John D. - Minneapolis 'Burbs
    It's true. Been repeated lots of times in multiple posts plus my own experience. But I agree, mount it where it make sense. Check all the clearances and hookups.
    Position it so that you can get the upper hose clamped on and let it fall where it may whether that is center or offset.
  7. Likes FlyFactoryFive liked this post
  8. #6
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    I just installed my radiator and I offset it the 5/8" because I wanted the side aluminum pieces to fit properly as designed. I wold have rather had it centered (just because i like symmetry) For those who center theirs what do you do about the side pieces?
    -Tim
  9. Likes RBachman liked this post
  10. #7
    Raleigh NC, OIB NC
    Radiator looks a bit funny with the offset but you need it for clearance. You can hide the whole thing behind a Nomex honeycomb that will also protect the radiator from stones.
    Kevin
    MKIV #8234
  11. Likes Higgybulin, tbl100 liked this post
  12. #8
    Fairfax Station VA
    Quote Originally Posted by tbl100 View Post
    -Tim
    I had absolutely no luck getting the F5-provided aluminum pieces to fit. With the curve of the aluminum side pieces placed to match the contour of the body, I had a 1”+ gap at the bottom of each side piece. Also, the bottom piece was too long to fit between the outriggers (easy enough to trim) and also too wide to fit between the bottom of the radiator and the lip of the body opening. So I ordered the Mike Everson piece (http://www.replicaparts.com/Roadster...nel%20page.htm).
    MK IV Roadster #8631
  13. Thanks tbl100 thanked for this post
    Likes tbl100 liked this post
  14. #9
    Raleigh NC, OIB NC
    +1 on Mikes part. Never even considered using the FFR pieces. Wanted a smooth no seam duct.
    EDIT: Forgot to post. The two pieces seal against the body forcing 100% of the incoming air through the radiator. Don't recommend it but have never installed the fan shroud I got after the car was finished. Car has been through 4 Carolina summers as a daily driver & the water temp has never gone over 210*F stopped in traffic. Normal running temp is 180*F with the factory thermostat.
    Kevin
    MKIV #8234
  15. Likes tbl100 liked this post
  16. #10
    Before you do all this take a big hammer and knock your driver side frame horn towards the passenger side a .5 inch....knock the pass side outboard 1/4 to .5. It's where they need to be,,,da bat
  17. #11
    Mar 2019
    Roseville, CA
    Thanks John. I placed the side pieces in where I think they belong and noticed a big gap between the pieces and the radiator but was not going to pass judgement until I had the body on and could see how it all came together. Now I'm not as confident. If I end up not using the F5 parts and go with something like the Mike Everson piece I'll go back and center the radiator if it doesn't cause any problems.
    I'd sure like to use some of the parts I got with my complete kit, LOL. I've upgraded a lot of stuff already.
    Tim
  18. Likes phileas_fogg liked this post
  19. #12
    Jax Beach, FL
    Quote Originally Posted by j.miller View Post
    Paint fumes and a BFH and Jeff can fix anything!
    The side radiator AL pieces on mine weren't even close. I made some new ones. I agree, mount the radiator based on everything clearing with centered as possible being second.
