Thread: Floor mats for MK II roadter
    Anyone know of a site from which I can purchase floor mats for a MK II Roadster? RJF
    Dec 2012
    Houston, Texas
    Finish line accessories has them.
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
    Mar 2018
    Maryland
    I ordered them through Finish Line in January and never received them. Not sure about now.
    I ended up ordering the Factory Five ones, they should be back in stock at some point.
    http://www.factoryfiveparts.com/1471...1-2-floormats/
    Super Moderator
    Ray's Avatar
    La Mesa, California
    I have polished diamond plate in our car.
    Ray
    Francky
    Thanks for the lead and the head's-up on order fulfillment.
