Thread: Paint Brands
    Paint Brands
    I recently ran out of 2 part high build urethane primer. A trip to my local automotive paint store (where I am supposed to get a small discount) almost caused a heart attack from the high cost of some replacement. That same day I received a Summit Racing "tools" catalog and they had a good selection of automotive paints. The 2 part high build urethane primer they carried was about 1/2 the price of the automotive paint store.
    The question is, have any of you builders used the Summit paints and were you happy with the results?
    Paint and prep materials aren't the place to cheap out. I use PPG and Evercoat products exclusively. Do you really want to gamble on an off brand for the the bottom foundation layer to save 60 bucks and then spray $1,000 to $2,000 or more worth of base and clear on top of it?
    Senior Member Jetfuel's Avatar
    Aug 2018
    What Jeff said, no need to cut corners with something that everybody and their brother are going to see.
    You should see my bill for primer, sealer, base and clear from PPG envirobase....but I know that in the end it will be what I want it to be and last a long time.
    Jet
    Feb 2018
    Half Moon Bay California
    I have been using summit racing urethane primer and the summit clear for a couple of years.
    A lot less expensive then anything I can find locally and it has held up well. I painted my jeep Cj and my daughters tj a couple of years ago with no issues. I do use the omni brand base coat but summit clear. I am not sure who makes summit products but it's a quality product. I am actually in the middle of painting my roadster now and just sprayed the urethane primer last weekend.
    Like Jeffski, my pal Ernie (Founder & Owner / Dependable Paint & Body / Slidell, La.) also exclusively uses PPG & Evercoat products.
    https://www.collisionrepairslidell.com/
    40 years later his shop is still the most reputable one in town and his little shop has taken care of our fender bender and/or painting needs since the early 1980's.
    https://youtu.be/A5WUZgl6N5Q
    He'll be mixing all of my paint and we'll be using his booth when we do the final spray-out our MK-4.
