I’m running the cables for the E-brake with the Wilwood brake upgrade. There is a plastic clip holding the end in the transmission tunnel, but nothing holding the sheath near the caliper. It looks like a retaining clip should be there holding it. Am I missing something?
Rob
There's no clip called out or in my experience necessary. The sheath/cable is stiff and under a bit of tension. When anchored to the Wilwood caliper, it's not going anywhere. Three seasons and 6,000+ miles on my 20th Anniversary Roadster with this setup.
Build 1: Mk3 Roadster #5125. Sold 11/08/2014. Build 2: Mk4 Roadster #7750. Sold 04/10/2017. Build Thread Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 Coyote. Legal 03/04/2020. Build Thread and Video Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Legal 04/20/2023. Build Thread. Sold 11/9/2023.
The cables are the same regardless of caliper type. From the factory, the mustangs had the cables installed on the rear end, and would fall out of the caliper before installation in the car. They had clips so the sheath would not come loose when hooking up the front. They were only there for that reason, or they would fall out of the caliper going down the line. They are not needed for the operation of Parking brake. As stated above the cables or sheath never move if the cables are even remotely snug.
Not that anybody needed to know, but there is also no need for a rush on e clips, LOL. HTH, Richard.
