Do you have any measurements of that hitch? How has it worked for you?Here is a couple of shots of the trailer hitch I built. I don't know about the rest of you guys but around here if you are going to spend much time outdoors, you need a way to get out of the sun. That means an EZ up is mandatory - along with a chair or two and a cooler for the appropriate chilled beverages. The trunk on this thing ain't gonna handle any of that so I figured I better come up with a way to pull a small trailer. I pretty much copied Eric's build for that part. It will also come in handy for supporting the trunk floor.IMG_0952.jpg
