Results 1 to 8 of 8
Thread: TKO 600 hook up question
    Accord NY
    I recently installed a new TKO 600 to replace my old 500. I have a wire that I’m not sure how to connect. Attached is the wire and the location on the transmission of where it goes. Do I need a different piece in the transmission or a different connector? I believe it’s the back up light switch.
    Craig
    Jun 2018
    North Vancouver, BC, Canada
    Yup, there's a number of sources Summit Amazon etc
    Here's what you're looking for https://www.summitracing.com/parts/r...SABEgLTUvD_BwE
    Gen 1 '33 Hot Rod #1104
    Accord NY
    Hi Steve,
    I guess I just replace this with the connector I currently have and good to go?
    Edmonton Alberta
    I tried to make something fit with no luck and ended up getting the pig tail shown above by Steve. It works.
    David W
    Mkll 4874 built in 2004
    Accord NY
    Thanks. Just ordered one.
    Jun 2018
    Yup, just cut the current connector off. Polarity on the switch doesn't matter, there is no polarity for the TKO connector
    BTW, if you haven't seen it, here's a diagram of the different TKO connections. Electric speedo connection is on the passenger side
    Post #9: https://thefactoryfiveforum.com/show...reverse-switch
    Dec 2018
    Hudsonville, MI
    Thanks for posting this. Maybe this is something I missed. Is the backup light circuit already integrated into the RF harness? Didn't realize it might be as easy as simply adding this connector.
    Coupe Kit Delivered 11/10/23
    No, there's no backup light wiring in the RF harness. It's easy to add though. Pull a wire from an ignition switched circuit. On my Coupe, I used the radio wire since I don't have a radio. But others would work too. Especially if you use an LED then the current draw is very low. Go through the rear harness and in/out of the TKO switch. Ground the light at the back. When the transmission is in reverse, the switch is closed powering the backup light(s).
  9. Thanks MSumners thanked for this post
    Likes FF33rod liked this post
