Results 1 to 18 of 18
Thread: Tremec TKO reverse switch
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Seems that I've been bit by the "assume" mantra again... Don't assume, 'cause it'll make an *** out of U and ME.
    When I was doing the rear wiring on #9365, I prepped for reverse/backup lights. I assumed the switch on the Tremec was an N.O. (normally open) switch, that closed when the gearbox went into reverse. It appears that this is not the case. It goes "open" on shifting to reverse.
    Question is:
    Does Tremec offer a N.O. reverse switch?
    John D. - Minneapolis 'Burbs
    2bking's Avatar
    Garland, Texas
    Are you sure your on the right switch and not the neutral safety switch. The reverse switch is on the tail shaft and should be a N.O. The neutral safety switch is closed in neutral and open in all gears.
    King
    Aug 2017
    Minneapolis 'Burbs
    The switch I'm tapped into is on the extreme end of the tailcone, driver's side, just forward of the output shaft seal...
    So. Bay (So. Calif.)
    The reverse switch looks to be on the DS mid section. The neutral safety switch is on the tail section. The manual shows F7 as the reverse switch, and F18 as the neutral safety switch.
  5. Thanks WIS89 thanked for this post
    Aug 2017
    Minneapolis 'Burbs
    It would certainly help if I connected to the correct switch now, wouldn't it! clonk.gif
    BadAsp427's Avatar
    Greeneville, TN
    Or you could just add a toggle switch to the dash board for the reverse lights..... Naw, Just connect to the right one.
    Heart of Dixie, Alabama
    Now I will have to go check and see which switch I wired into. Better now than later, thanks.
  9. #8
    2bking's Avatar
    Garland, Texas
    Yep, I got them backwards, The backup is forward and neutral on the tail shaft. But connecting to the correct switch should make the reverse lights work.
    King
  10. #9
    Mark Eaton's Avatar
    Medford, Oregon
    Ok, just to be clear do I have this correct? This is my TKO 600
  11. #10
    Aug 2017
    Minneapolis 'Burbs
    Reverse Switch Questions & Answers
    Mark... your pic/diagram is correct. The reverse light switch is about centered in the driver's side of the main case.
    (Like a knucklehead clonk.gif, I left all my tools on the cart at the jobsite, knowing that my "home" meter is a K.I.A. - coulda saved myself a bit of work & embarrassment with a simple check with a meter!)
    When I ordered my trans from Forte's, I also ordered a reverse backup switch (not knowing one was supplied/installed with the gearbox). The "replacement" switch has a Weatherpak connector molded in, unlike the raw studs from the factory. I chose to swap them for the better connection/waterproofness/etc.
    If you're going to swap to the different switch, the good news is the switch is "dry" - It's above the level of fluid in the case - no cherry-juice bath. **However there is a very thin nylon sealing washer under the head of the switch**. Look out for this as it can get stuck to the case or the switch, be sure to transfer it.
  12. #11
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Glad I tripped over this thread. On the right track (now).
    Question - If not using the neutral safety switch (don't think I need to ?), what should I do with the pigtail ?
  13. #12
    Sep 2015
    Beachside
    I just zip tied the pigtail up and out of the way in case someone in the future wants to connect it.
    FFR #8833 289 FIA 3-link
  14. #13
    Aug 2017
    Minneapolis 'Burbs
    I did one additional thing - I plugged a mating 1/2 of the connector in the other side, and sealed the wire holes with a dab of silicone.
  15. #14
    Sep 2015
    Beachside
    Good idea, keep the road junk out
  16. #15
    Jax Beach, FL
    I remember having trouble finding the right pigtail for the backup sensor. Modern Driveline has them.
  17. #16
    Folsom, CA
    where did you pull power for the reverse switch? I have a TKX and implementing a backup light as well
    assume you just ground one side of the switch into the frame?
    Todd
  18. #17
    Senior Member Nigel Allen's Avatar
    South Australia
    one side of the reverse switch to ground will work. Just make sure you use an ignition switched positive for the feed to the reverse lamp, otherwise if you park the car with transmission in reverse you will end up with the lamp on all the time.
    Nige
    Gen1 Coyote / TKO600 / IRS
  19. #18
    Oct 2020
    Albany, NY
    Quote Originally Posted by toadster View Post
    What Nigel said. I used the keyed accessory power. This runs my backup light as well as my charging port.
  20. Likes toadster liked this post
