Results 1 to 3 of 3
Thread: door woes
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Aug 2019
    Fort Lauderdale
    door woes
    I am close but no cigar; with nothing tight, the doors fit nicely in place but as I tighten, everything seems to want to "walk" a bit. I am using a length of ¼ all-thread as a single hinge pin, to keep the hinges parallel but by the time I get everything snugged-up, one or more of the corners is out of position. Seems like things need do be done in a particular order to avoid conflicts - and I have yet to figure out the sequence
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Howdy Mike!
    Is the difficulty equal on both sides, or as some of us have discovered, it is far more challenging on the passenger side?
    Best of luck 😁😁
    Pat
    Aug 2019
    Fort Lauderdale
    The passenger side - seems like I need to shim the hinge away from the door; drivers side really close.
    thanks for the update; anyone know why?
