6
34
Originally Posted by
Erik W. Treves
just an observation - on the front suspension - if your A-Arms are torqued and that's why they appear to be able to support the disk and all without any aid? You will want to loosen all the attachment bolts and re-torque them at after ride height is set with weight on the suspension - it appears that you have the "relaxed" state of the bushing at full compression right now.... again only an observation.
Thanks for the advice! Torquing with weight on the vehicle at ride height makes sense, added to the list
