The fit inside is the same as the Gen 3 coupe which I am happy to report is HUGE. I would make the observation that tall is relative to whether you are long legged or long in the upper body... myself I am 5'6" with 31inch inseam and I have the seat as high up as I can get it (Kirkey) and I am sitting on a one inch cushion as well as having the seat moved forward - If you go on the Coupe forum and ask the question you will find your answer I believe. I haven't check myself side by side ( i have a coupe as well) - but the A-pillar roll bar is more forward so I think this will help with the entry as well.
my .02
