Yes, like David said, I'd be surprised if anything was flexing on the front footbox part. It's possible the aluminum "cover" on front of the footbox is covered a bit by the adjuster and it's flexing a bit. My cover isn't perfectly flat and flush against the metal plate. It's doubtful the steel plate behind it is moving.
