Hi all,
Just wondering...has anyone used this approach as an interim solution between sanding and painting while deciding color?
Hi all,
Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
My friend Craig (Mechie3 here on the forum) dipped his 818. I think he detailed the process in his build thread.
Looks great!
FFR Roadster Delivered 9/16/21
Forte 427 Fuel Injected with TKX Transmission
Forte's Axle
I'm going to show my ignorance here...DIP?
It is a peelable paint.
https://www.dipyourcar.com/
I did some wheels in the past with the stuff worked great. When I black out my car this is what I will be using on the windshield frame so I don't have to risk the glass by pulling it apart. The only concern I have with it for a whole car is it doesn't react well to heat so not sure what it would do below the doors near the exhaust pipes.
Also you will still need to do all the bodywork before you dip the car for proper adherence which is the majority of the time/cost of paint anyways. Once that is done your not saving much over just painting it.
Isn't it a lot of work masking and spraying plasti-dip? Also, the body needs to be prepped well by sanding and bondoing... Prep steps are pretty much the same as the painting process. I believe the pre-pandemic price without the body-prep was in the $2-3,000s if you have the professionals do it. DIY is certainly doable, but just like painting, it might not come out clean... Plasti-dip has the same issues as the painting such as runny spots, zebra effects due to uneven coverage of the material... Lastly, when you want to peel them off, it's going to be a nightmare since the dip will be in every gap and hole... IMHO, I would just look at many paint samples, other finished cobras and paint mine permanently once and be over with it.
Sorry paint guy Jeff. I defer to your wisdom and endorsement.
jim
Car dipping
RJD, that's a great pic. Since it's in the 4 ft side of the pool would it be skinny dipping?
MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
Now I know! BTW...thanks rthomas98!
did my wheels with this as well. then one time I forgot about it (yes, this stuff does look good), and tried to power wash the wheel. realized my mistake a bit too late, so then still used power washer to strip the paint. repainted and looks good. this stuff definitely helps to experiment with some color options, and make a decision. Probably will powder coat these wheels later though
Build thread
FFR mk4 roadster complete kit, 347 cu in carbed BluePrint engine, TKO600, IRS, power steering, ordered Jan2020, delivered 3/25/20, titled 8/23/20, finished 07/17/2021, graduated 10/06/2021
......"your car" isn't what comes to mind when I hear the word "Dip"...........WHAT!........Jus say'n.......I'm in one of my dark moods.......(music swells)....YOUR A MEAN ONE , MR. BAT, YOU'RE BALDING AND YOU'RE FAT, YOU'RE A DRUNK AND WOMANIZER, WON'T TAKE A SHOT FROM PFIZER........Come on man......you know the thing...Brandon. whoops I mean ...da Bat
