Thanks Thanks:  6
Likes Likes:  79
Results 1 to 40 of 66
Thread: Hemi Powered SPEEDSTAR in the HOUSE!
    Huntsville, Al
    Got the Beta car in the garage to update it to the production body and glass.... this thing is a beast!!! stay tuned!
    Port Charlotte, FL
    We’ll be watching! ��
    Henry
    Erik,
    Do you think that windshield wipers will be on the list of upgrades for that car?
    Many states require them so I was wondering if it was on your list for update options.
    Thanks-N-Advance!
    Jun 2018
    North Vancouver, BC, Canada
    Erik,
    Thanks-N-Advance!
    Hey Steve
    Wipers aren't even an option on the regular hotrod. However, Dan Ruth has a package he's put together, some have used mighty wiper, and there's a universal brand (can't remember off the top of my head) that works really well. Some put them in the cowl and some put them above the windshield.
    For the Speedstar, it will be interesting to see if the final cowl design has changed to something more like the hot rod. From the pic above the hood is coming right up to the windshield and with the roof slammed there is questionable room above the windshield.
    Gen 1 '33 Hot Rod #1104
  5. Thanks GoDadGo thanked for this post
    Hey Steve
    Thanks Steve,
    My friend Dave just completed a 33 Hot Rod and had to install a 2-speed electric wiper to get the car to pass.
    It was a marine unit that clamped on the top of the window frame which was removed shortly after the inspection was completed.
    When he has to do the Annual Safety Inspection (A.S.I.), he plans to reinstall the sucker and then put it away until the following year.
    Thanks Again!
  7. Likes FF33rod liked this post
  8. #6
    Aug 2011
    San Jose, CA
    Oh wow. Keep us posted.
  9. #7
    That is a beautiful body shape. I am surprised that more Speedstars aren't being built.
    I'll be following along on this one!
  10. #8
    I’m a big fan of the Speedstar and have been working hard to convince Nancy that she likes it too When I worked the FFR display at the Street Rod Nationals this summer it generated a lot of interest and positive comments from the crowd.
  11. Likes FF33rod liked this post
  12. #9
    Oct 2019
    Erin, Ontario CANADA
    I have always been a fan of the Rat's Glass/Alloway roadster design and was very excited to learn that FFR was carrying on the platform with their advanced frame design underneath it all.
    If only FFR would do a roadster version like the 33HR!
  13. #10
    Oct 2019
    Perhaps it might be possible to mount the wiper motor right into the hood?
    Earl
  14. #11
    Quote Originally Posted by narly1 View Post
    Earl
    The hood hinges from the front. Theoretically I think the wipers could be mounted to the cowl that is under the rear edge of the hood and the hood could be cut out to clear the shafts. Me? I’d use Rain-X
  15. Likes RoadRacer, FF33rod, narly1, WIS89 liked this post
  16. #12
    Huntsville, Al
    the only "issue" with wipers +cowl is that there isn't a cowl on the speedstar - notice how the hood goes all the way to the windshield vs the HR that stops well short. So indeed you would need to hack up the hood to accommodate the wipers.
  17. Likes narly1 liked this post
  18. #13
    Aquapel FTW! I had a temporary wiper for the reg (in the end no one looked or cared, FWIW), and haven't missed them since. Aquapel works well enough to drive my 33 in thunderstorms
  19. #14
    Oct 2021
    Hey Chief,
    My SpeedStar is on order, June 2022 delivery.
    5.7 Hemi and a TKO.
    Can you answer a question about the oil pan?
    FF recommends an aftermarket road race pan, will a rear sump not work?
    Is it a ground clearance issue?
    Also, what is the ground clearance under the grille?
    Speedbump issues?
    Great looking car!!
    Thanks Much!!
  20. #15
    Huntsville, Al
    The speed bump question or answer is - it really depends - how low will you run your car? how big a speed bump? - at the book height this the where the grill lands - it basically has the same ground clearance as the 33 HR.
    As far as the pan - it is a clearance issue - the pan they recommend put the pan even with the frame rail...
    must be fall but you can just see the pan here:
  21. Thanks theidlemind thanked for this post
    Likes theidlemind, FF33rod liked this post
  22. #16
    Huntsville, Al
    Work, before WORK this morning - just need to pull the doors off - and off to paint the panels we have and wait for the production body -
  23. Likes FF33rod, theidlemind, Geoff H, shmelty liked this post
  24. #17
    Oct 2019
    My thinking was that the motor, arm and blade would all lift away with the hood, with the wiring running all the way to the front and back again.
  25. #18
    Huntsville, Al
    you would need to make "pockets" in the cowl - and then a channel for motor and drive cable? not saying it's impossible but I think it would be a "mess" and make the hood pretty heavy?
    might be better to "slot" the hood? ANyway - just thinking out loud - I have no intention of attempting anything like this on this one
  26. Likes narly1 liked this post
  27. #19
    Senior Member Nigel Allen's Avatar
    South Australia
    Hi Erik,
    I didnt know that Factory Five did push bikes....
    Cheers, Nigel.
    Gen1 Coyote / TKO600 / IRS
  28. #20
    Oct 2019
    Erik,
    I don't disagree with your assessment.
    Or perhaps mount the motor into the window frame/headliner I guess. But as mentioned previously there's not a lot of room for that. And it would look like crap in a roadster version.
    Earl
  29. #21
    Jun 2020
    SoDak
    Mounted my wiper with the motor shaft coming through the cowl and winshield frame, turned out great, also works great. Barely notice there is a wiper there.
    Attachment 141680
    Attachment 141681
    Attachment 141682
    Attachment 141683
    Attachment 141684
    Attachment 141686
    Attachment 141747
    Attachment 141748
    Jim
  30. #22
    Oct 2019
    Attachment 141680
    Attachment 141681
    Attachment 141682
    Attachment 141683
    Attachment 141684
    Attachment 141686
    Attachment 141747
    Attachment 141748
    Jim
    The difference though with the Speedstar is that the hood comes all the way back to the base of the windshield. It's one of the design elements that gives it it's smooth look.
    Earl
  31. #23
    Frankly, adding wipers to a Speedstar would be difficult but even more than that is that aesthetically it would border on criminal. And that’s all I have to say about that
  32. Likes narly1, FF33rod, Chris C, Cobradavid liked this post
  33. #24
    Jun 2020
    SoDak
    Earl
    Ah, wasn't aware of that
    Jim
  34. #25
    Oct 2019
    All the more reason why I'm hoping for a roadster version. Clamp an el cheapo wiper arm/motor to the top of the windshield frame for the safety inspection then toss it.
    Almost every interpretation of the original Speedstar design I've seen has been as a roadster, a few with soft tops.
  35. #26
    Placitas, NM
    Drill a hole thru the windshield and mount one of those manual wipers if you have to have one to pass inspection. Then remove it and put a plug on the hole.
    That’s what I’m doing on my 33, but using a single speed motor mounted inside the top part of the roof. We need a wiper to pass inspection.
  36. #27
    Oct 2019
    The concern is that the chopped roofline of the Speedstar leaves little room for a wiper motor.
    Earl
  37. #28
    Placitas, NM
  38. Thanks narly1 thanked for this post
    Likes theidlemind liked this post
  39. #29
    Oct 2019
    Keep those updates coming when you can Erik.
    Earl
  40. #30
    Huntsville, Al
    First few parts coming out of the paint booth - still needs cut and buff....lol....
  41. Likes RoadRacer, theidlemind, Geoff H, WIS89, HVACMAN liked this post
  42. #31
    Oct 2021
    [QUOTE=Erik W. Treves;479793]First few parts coming out of the paint booth - still needs cut and buff....lol....
    It looks to me like you've got a bunch of mirrors laying around your shop.........
    That depth!
  43. #32
    Oct 2021
    Progress pictures?
    Also, Is the Hemi AC compressor on there?
    Will it fit? The Factory Five Hemi fitment .pdf doesn't mention that.
    Thanks!
  44. #33
    Huntsville, Al
    The main body is going into primer hopefully next week - really just waiting on that. There are no side windows or AC in the car. I did take the Grill up to western Tennessee to get chromed so that is was a step backwards... should start going back together some time by the end of the month.
  45. #34
    Hey
    I’m building a 33, 6.4 Hemi , TKX 5 speed with A/C, using Restomod AC system. I have the Road race pan so it will above the frame, I went with CVF serpentine system with compressor on right and Alternator on left. I have not received the Hemi install kit yet? I picked up my kit November. Waiting on a lot of parts, Good to see some Hemi builds!!
    Pat
  46. #35
    Huntsville, Al
    Quick update - the single picture does quite cover how much work it takes to get the body prep'd to take a black gloss paint job - but it is nice to see all the main areas covered and the filler finally laid in nice and smooth....now to let it sit in the sun for a bit....
  47. Thanks WIS89 thanked for this post
    Likes WIS89, j33ptj, narly1, shmelty liked this post
  48. #36
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    I take it that the body and roof are one piece?
    Just curious....
  49. #37
    Huntsville, Al
    yes
  50. Likes j33ptj liked this post
  51. #38
    Huntsville, Al
    Well it has taken another month to get to this point - getting the body laser straight to accept the black paint was a critical step!! But after about 5 rounds of blocking - lost track - I think we finally got there... my painter also bonded the entire dash section into the body and smoothed it out so it's one continuous piece! The interior is also already finished and painted as are the interior jams ... all gloss black.....
    Here we are yesterday at around noon:
    and then around 11pm last night right out of the paint booth
  52. Likes FF33rod, JimLev, BadAsp427, shmelty, WIS89 liked this post
  53. #39
    Apr 2019
    Wow!!! We’ll done
  54. #40
    Huntsville, Al
    Start re-assembly today... got to shop around 9am this morning and put a good 8 hours into the car today - the painters were still buffing parts but we figured out how to get keep out of each others way... this is just the first pass with the cut and buff - no polish yet.... It should be pretty sicko when done...
  55. Thanks WIS89 thanked for this post
    Likes WIS89, narly1 liked this post
