Shakey's Daytona Build
Greetings all,
After years of watching from the sidelines it’s my turn to start my build thread. Plan is for a trackable streetcar that I can drive most of the year. Even when the weather gets less than perfect. Details for the plan are below.
Kit Order:
Coupe Gen 3 Base Kit
Black Powder coat
Body Cut-outs
FFR Front lower control arms
2015 IRS
Hydraulic Clutch
Platinum Gauges
Carpet Kit
Side Windows
Front and Rear Swaybars
3.55 Center Section
Heat and A/C
Engine and Trans:
SBF 347 with Fuel Injection (Sniper or Pro Flo 4)
T5Z transmission
Brakes:
Wilwood 14in front and 13in rear with mechanical parking brake
Steering:
Power steering
Unisteer 2.5 turn quick ration steering rack
Moog Tie rod ends
Russ Thompson Turn Signal
Wheels and Tires:
Forgestar F14 Golden Bronze Front: 18x10 +12mm offset, Rear: 19x12 -25mm offset(Thanks Logan!)
Tires Nitto INVO Front: 275/40R18 Rear: 325/30R19
Odds and Ends:
Digital Guard Dawg
Second Skin Firewall, Damplifier pro, luxury liner
Corbeau A4 seats
GAS N Headers 1 7/8in and side pipes, ceramic coated white. (not sure what the best way to get these coated is. DIY or through a vendor.)
Kit was ordered the first week of December. Scheduled delivery date is July 23, 2022. I’ll spend the next 7 months gathering parts and continuing to plan. I would be interested to see if anyone sees and issues with the parts list or build plan. Can’t wait to get started!
-Shakey
Congratulations and thanks for sharing your build with us. Look forward to following along.
FFR Maven
Congrats and welcome! Where are you from?
Glad I could help on the wheel and tire choices. Post pictures when you get them.
Hey thanks guys! I'm from Mount Vernon, Washington. About an hour north of Seattle.
Congrats, sounds like a solid plan!
Originally Posted by
Shakey
Shakey,
Sounds like a great car. Hope the time flies by. An hour north of Seattle is almost Canada, eh? I was lucky enough to play Semi-ah-moo a number of years ago. Beautiful countryside.
Congrats on the build. I grew up on Whidbey Island...
It's a small world. My wife is from Prescott Valley.
Kit Cart
I have seen a lot of posts about people worried about getting their kit from the Stewart truck into their garage or shop. I am definitely one of those people. Where I live I have about a 50 yard gravel drive that slopes downhill to get to where my shop is. There is about 15 feet of total elevation drop. I been trying to think of how to take delivery of my kit. I decided to build a big cart with some decent size wheels on it and use my riding mower to tow it down the driveway. I figure the Stewart rig could just drop the kit right onto the cart I made and I can use some friends or a couple jacks to lift it off once it is in the shop. Pic below is of the whole setup.
Shakey
Just in case you have not thought about it. You will want to strap down the frame/body to keep it from sliding off the dolly.
Hey Sankey. similar boat here with the delivery. 300 yards of road base driveway and way too small of gate and angle for a direct delivery. I used 4x4 over the rails of my 6x10 trailer. strapped it down and moved it up to the garage. had to get creative on getting it back down to ground level to be placed on jack stands. Little help with the engine hoist and 3 buddies and we got it done. Doug
As I just received my kit two months ago i also have a driveway that slopes downhill. The delivery driver has a cart with decent size tires and a strap to help hold it back someone will steer it. They have encountered many different driveways and have the necessary tools to deliver your kit safe and sound. We didn’t have to strap the car to the cart but that would not be a bad idea if your driveway is long.
Congratulations. welcome to the fun.
Definitely some good ideas out there. Sounds like the long/gravel drive is a common issue that folks tackle on a regular basis. I will make sure to strap everything down well before I start moving it. I have heard that the use of 2x4s under and pushed through the frame can make useful lift points.
Thanks guys for sharing your delivery experience. Seeing how other people do it really gets the wheels turning to help think through the problem.
Engine is ordered!
I finally started ordering parts for the project. I figured I would start with the biggest and most expensive part. Here is what I decided on.
SBF 363cu.in.
Dart SHP 302 Block
Forged internals
AFR 205 Heads
Hydraulic Roller
Edlebrock Super Victor Intake
Moroso Road Race Oil Pan 7QT rear sump 7.5in depth
11:1 compression
Billet specialties Tru Trac Serpentine System with P/S and A/C
Comp cams custom grind camshaft
Holley Terminator X Sniper Stealth with Hyperspark
As many of you may know, Dart has quite the back order. I was given an estimate of 10 months for completion of the motor. I am hoping to receive it in November of this year. My kit is supposed to arrive late July so, there may be a bit of a hold up on the build waiting for the motor. Not too much though as I will be on a work trip of a few months this fall anyways.
I was a little hesitant about the Super Victor Intake but, by my math. It should fit.
I estimate the total clearance space available from top of the engine block to the hood is 12.5in
Holley stealth height= 3.28in
Super Victor intake= 6.35in
Drop base air cleaner=2in
Hood clearance= 0.5in
Total= 12.13in
So it should fit.
More updates to come as I keep ordering parts.
V/R
Shakey
Shakey, just a suggestion, but you should try and place the fuel regulator as close to the destination as possible. It can help reduce pressure variations at the injectors.
Hey Skuzzy,
No, I haven't gotten around to the fuel tank install yet. Probably December before my motor arrives. I was just reading through the instructions that Breeze sent. It does seem a different way of installing than I have seen before. I would be curious if anyone has used the filter/regulator combo near the fuel tank in the past.
Shakey
Shakey
Hey Skuzzy,
Shakey
Whole bunch of builds with that GM regulator back by the tank and the resulting short return line and single supply line up to the engine. Not to mention all the Corvettes GM put it in.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
edwardb
Thanks for the insight! I feel a lot better going with what Breeze is recommending now.
V/r
Shakey
edwardb
No disrespect meant, but we are not working with a system which has been seamlessly designed to function together, from one end to the other.
During hard acceleration, the mass of the fuel, in the line, is going to cause a momentary pressure surge, back to the regulator. This moment causes the regulator to drop pressure in the line. During hard deceleration, the reverse happens.
How much of an impact it can have will be determined by how much overhead the system has and how sensitive the controller is to changes in pressure.
My personal design philosophy is to be better safe than sorry. Yes, it is a hassle to put the regulator close to the engine, but it is the best choice, for a system composed of disparate components.
Reason: Got ahead of myself.
Congrats man! for whatever reason I can't see your pictures...
Pictures are not showing up, but I get the gist of it. Congratulations and stay safe out there!
Hopefully the pictures are visible now. I had the album set to private. Oops. Please let me know if they are still not showing up.
Thanks.
Yeah they are visible, delivery days never get old!
Wheels ordered
I went ahead and ordered my wheels recently. I have gone back and forth for a long time on what wheel look I wanted and, like many others, I have landed on the Forgestar F14. There are other wheels out there that I like the look of more but, at the price point and offsets available, I think the Forgestar wheels are the way to go.
I called up Jason at Get Your Wheels and he was super helpful. Turns out they have a database with all FFR 65 coupe orders and what offsets/specifications were ordered. Ordering wheels without having done any measurements myself made me a little nervous. With the help of Logan's thread and the data from GYWs I felt pretty good about placing the order.
Here is what I ordered:
Fronts: Forgestar F14 SDC 18x10 +12mm offset 5x114.3 bolt pattern
Rears: Forgestar F14 UDC 19x12 -25mm offset 5x114.3 bolt pattern
ACC Hubring 70.6 on all 4 corners (This is per their recommendation)
Color: I am having them finished in a Gloss Brushed Antique Bronze, Pics below.
They quoted me 10 weeks or so for delivery time. I will post when I get them in hand and bolted up.
Looking great. You're making good progress. Too bad about the front spindles. Those seem to go out of stock somewhat regularly unfortunately. They're made overseas and I know have a long lead time. But six months does seem like a long time. Hopefully FF will get you an answer and the parts soon. The hubs are generic Mustang SN95 parts, available all over. Really not a good reason for those to be backordered. But having said that, I know you'd like to see a roller. But you have tons of things you can be doing without the front suspension completed. Hopefully you're not locking yourself down to the manual build order. Brake lines, fuel lines, electrical, finish riveting all the panels that in your picture aren't done yet. Even drop the engine in and working from there. Unless you have an extra long shop crane or an overhead setup, you're going to want the radiator out of the way to install the engine. I have the 2 ton HF version, and it was all the say out without the radiator in place. I know some Roadster builders put them in from the side. Haven't tried it and don't know if the Coupe would be an option.
Build Thread and
Video.
Build Thread and
Video
Shakey
Before I discuss the kit delivery, I will take a few minutes to set the scene. Long story short, I am in the Navy and was set to go on a routine deployment September of this year. Because of world events that occurred earlier this year my deployment got moved up by a month. I ordered my kit in November of last year and it is hard to predict what is going to happen 9 months down the road.
As fate would have it, I left for deployment on August 12th and Stewart showed up the next day. Big shout out to my awesome wife and friends for stepping up to take delivery of my kit. They did a great job of getting it down the gravel drive and into the shop where it will have to wait for a couple months until I can start work on it.
They sent me plenty of pictures…..
Obligatory Stewart truck shot.
This is a good view of the custom cart I made in preparation for the offroad trip to the shop.
I guess they blocked the whole street for a little while. That road is not too busy, and no traffic issues were passed to me.
All loaded up and ready to move. If you look closely, you can see some ratchet straps going through the frame holding the kit to the cart.
The lawn mower/cart combo worked like a champ. A lot nimbler than using a full-size vehicle.
All tucked in. Another benefit to using a cart that I built was that they just left the kit on the cart and didn’t have to mess with putting it on jack stands. That will be my first task when I get back.
I was out of town for my delivery too.... kind of a bummer! Thank god I have relatives close by....
Shakey
The biggest parts I have been waiting on has been the front two-piece spindles and hubs. It's been six long months and a bunch of e-mails/phone calls and I am still waiting on them.
Shakey
I received my coupe kit on 7/25/22 and just received my spindles and hubs the middle of December. Hopefully you will get yours soon!
Your build looks great, I love the finish on the wheels!
I like the idea of painting the radiator also.
Scott
Type 65 Daytona Coupe Complete Kit ordered 11/2021, delivered 7/25/2022....the fun has begun!
Shakey,
Interested to get your impressions on the A4 seats. I've been looking at those but haven't seen anyone else using them. Curious how the height is with the shaved base. I'm considering unshaved but hard to tell without having them in hand. Also interested in how well the side bolsters and seatback "wings" fit in the cockpit. Alsoo are you putting those on sliders? thanks
Shakey
I used a plastic cable glad to insulate the brake reservoir hoses as they pass through the foot box.
Great progress Shakey and thanks for the update. Any idea what size cable glad that is for the brake reservoir hoses? That is a slick detail. I found some rubber grommets at Ace hardware that fit and cut 3 holes into one, isn't pretty but guess it will work, but like the idea of something I won't need to be replacing due to cracking every few years - since that area is so visible would like it to look clean like that. Great little detail.
JMo
Shakey,
Hey John,
I love the look of the seats. I got them in the black microsuede from Mike Forte. Sitting in them, the side bolsters are very prominent and seem to hold you in the seat very well. I got the regular width seat and the sides are defiantly snug in the cockpit. The sides currently do not touch the aluminum panels just sitting in there but with sound deadening and carpet I think the side will rub a bit. These seats have a reclining lever that makes the fit between the seatbelt mounts really challenging. I had to remove the lever cover and do some minor cutting but the seat now fits between the belt mounts. It is going to be really tight to get the seatbelt bolts in there. I have not mounted them yet but will post to let you know how it goes.
I am planning to put the same Corbeau sliders(PN# C22059) Paul used in the car. That was the main driver for me getting the shaved seat option. I think the saved seat option helps a bit and is worth it. I think there is still plenty of padding in there to keep the seat comfortable.
I am 6'4'' with longer legs and a short torso. Seat height is not as big of a deal for me as the leg room. That's mainly why I wanted the sliders in there so others can move the seat forward to drive it. Also, for those with longer torsos, they can move the seat forward and recline if needed to get some more head room.
I'll get some more detailed picks next time I'm down in the shop.
V/R
Shakey
Shakey
Hey John,
V/R
Shakey
Hey thanks for the reply Shakey. Was a bit concerned about the placement of the belt anchors and the reclining lever but sounds like that can be made to work. Looking forward to seeing more...
rhk118
The cable gland in that picture is 1in NPT. Measures 1in inner diameter and 1-5/16in outer diameter of the threads. It was included in the kit I got here, https://www.amazon.com/dp/B08R86BHBC...t_details&th=1
V/R
Shakey
