Thanks Thanks:  23
Likes Likes:  189
Page 3 of 10 FirstFirst 12345 ... LastLast
Results 81 to 120 of 361
Thread: Mike in Texas FFR Roadster Build - Assembly, Going in the Right Direction
    Dublin, OH
    nice lines. I'm guessing you have plenty of clearance from the gas pedal to the rear and clutch lines?
    Dec 2021
    Flower Mound TX
    Yes
    Oct 2020
    Albany, NY
    Your brake and clutch lines are beautiful.
    Take a bow
    MK4 #10008 - Ordered 10/06/20, Delivered 03/03/21, First Start 7/22/21, First Go Kart 7/24/21
    Paint by Metal Morphous 5/14/22, Legally registered 6/8/22, Graduated 7/20/22
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
    Complete Kit, Ford 306, Sniper/Dual Sync, T5, Hydraulic clutch
  4. Thanks Mike.Bray thanked for this post
  5. #84
    Dec 2021
    Flower Mound TX
    More Brake Lines, almost finished!
  6. Likes Tim B liked this post
  7. #85
    Dec 2021
    Flower Mound TX
    Patch panel to cover the E-brake opening.
    And started on the dash.
  8. #86
    Feb 2022
    Flower Mound, TX
    Looking awesome. I need to come over and see your project!
  9. Likes Mike.Bray liked this post
  10. #87
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by OB6 View Post
    Come over anytime!
  11. #88
    Aug 2019
    Spokane, WA
    Wow! Those brake lines are too beautiful to cover up!
  12. Likes Mike.Bray liked this post
  13. #89
    Dec 2021
    Flower Mound TX
    More aluminum mocked up, need more Clecos lol Got good news yesterday from FFR, fuel tank, cover, and LCA's from my POL have shipped.
  14. #90
    BadAsp427's Avatar
    Greeneville, TN
    Out of Clecos... now just remove every other one and you will have a lot more...
  15. #91
    Dec 2021
    Flower Mound TX
    If you look closely you can see I've already resorted to that! It's fine though, several of the panels are ready for silicone and rivet.
  16. Likes BadAsp427 liked this post
  17. #92
    Feb 2022
    Flower Mound, TX
    I got to see them in person... very impressive indeed. Mike's got some skills!
  18. Likes 460.465USMC liked this post
  19. #93
    Dec 2021
    Flower Mound TX
    Skills lol I didn't show him the barrel around back full of the lines I scrapped!
  20. Likes 460.465USMC liked this post
  21. #94
    Oct 2020
    Albany, NY
    You only need about 20% of the cleco's your actually using. I only had 25 for my build and never came close to running out. Having said that your car looks really clean. It's coming along nicely.
  22. #95
    Senior Member Tooth's Avatar
    Nov 2020
    And got the brake and clutch lines in the footbox finished up. All of the hard lines are stainless steel with 37 degree AN fittings. To get from the cockpit to the outside I'm using bulkhead fittings.
    I pick up my kit in 4 days 20 hours 43 min, and 19 seconds. I'm drooling over the steel lines you put in. Where did you source them, and how much more difficult are they to work with. I'm thinking I need to do this.
  23. #96
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Tooth View Post
    Nothing like a countdown to delivery or pickup!
    The lines themselves are seamless stainless steel from Earl's. I have a set of the nice Rigid lever benders from 30+ years ago but unfortunately they don't make them anymore. For 3/16" brake lines this is the same as the Ridgid. https://www.summitracing.com/parts/fra-900501 They work really well at getting the precise angle and placement you need.
    I use this for cutting the tube. https://www.holley.com/products/plum...r/parts/003ERL After cutting I use a countersink in my drill to clean up the ID.
    Flares for AN fittings in seamless tubing are done with a 37 degree single flare tool. The aircraft grade ones have rollers on the flaring tool to burnish the tubing. I have this tool. https://imperial-tools.com/products/...flaring-tools/
    I've used both aluminum and steel AN fittings for brake lines but for the Cobra I went with steel fittings from Earl's.
    Get some welding rod to lay out your lines/bends before going to the expensive stainless tubing.
    And some useful tips:
    Never forget to install the ferrule before flaring.
    There is a minimum distance of straight tubing the flare tool needs to make a flare so plan accordingly.
  24. Likes Countrymile liked this post
  25. #97
    Dec 2021
    Flower Mound TX
    Plugging along with little things I can keep busy on. Got my first POL shipment, fuel tank & cover and the pin drive front suspension kit. My excitement was quickly dashed when I discovered the LCA's were there but the Spindle Adapter Brackets for my SN95 spindles were not in the shipment. Without the adapters I can't mount the front spindles. I did get the lower control arms mounted.
    And the fuel tank/cover/fuel lines plus the Breeze Big Bore Vent.
    Last piece of brake hard line is done.
    And the Breeze cubby hole cutout is done.
  26. Likes Fman liked this post
  27. #98
    Aug 2019
    Spokane, WA
    Hi Mike. I'm getting ready to install the Breeze cubby. What size hole did you cut in your rear cockpit wall?
  28. #99
    Dec 2021
    Flower Mound TX
    5" x 17.5" Used a 5" holesaw for the ends. Quick tip, don't ask the wife to hold the metal while using a 5" holesaw with a hand drill. Freaked her out a little.
  29. Likes 460.465USMC liked this post
  30. #100
    I found running a couple of screws through the waste section of the aluminum into a sheet of plywood, stabilized the aluminum while cutting the circular cuts. No spinning sheet metal, no chattering.
  31. Thanks 460.465USMC, Windsor thanked for this post
  32. #101
    Dec 2021
    Flower Mound TX
    Started on some Thermo-Tec installation. Very fun! I'm not sure if I'm doing a very good job or even doing it correctly but I'm doing asbestos I can
  33. #102
    There is no real right/wrong with this stuff. A couple of tips before you get too far, though. Keep it about 1/2 to 3/4 inch below the edges along the top edges of the trans tunnel to ensure you can get the cover on. Also, any panel that gets bulb seal needs to have enough surface to let the seal fully seat. Also, try to drill any holes you need (seat belt bolts, etc.) before covering those areas or be prepared to dig the goop out of your bits. If you do have to clean a bit, brake cleaner works well to clean the tar off.
  34. Thanks Mike.Bray, 460.465USMC thanked for this post
  35. #103
    Dec 2021
    Flower Mound TX
    It's been extremely hot here in Texas and that combined with my age (I was a waiter at the Last Supper) have really zapped my energy. But I have managed to get a few things done the past couple of days.
    Installed the Breeze roll bar, just need to drill and cross bolt it. The center to center spacing was off a little but a bottle jack fixed it.
  36. #104
    Dec 2021
    Flower Mound TX
    I received the fuel tank & cover on my POL list the other day and installed it. So time to run the stainless fuel lines. Not a very fun job.
    I haven't finalized this end of the lines yet as I'm waiting on the heat barrier to get here.
  37. Likes 460.465USMC liked this post
  38. #105
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    A little late to the party but Mike I cannot believe how good your brake lines look! I was pretty proud of mine until I saw yours LOL!
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
  39. #106
    Dec 2021
    Flower Mound TX
    Went away to the coast for a few days to cool off some and get some fresh shrimp. Now I'm back and this blistering heat here in Dallas is slowing me down. I'm just not young anymore lol
    I started last night installing the Wilwood remote brake bias adjuster. There's not much room in the footbox of these cars so I installed one of the little Tilton right angle adapters. https://www.summitracing.com/parts/TIL-72-560
    You have to look close, it's not easy to get a clear shot of it.
    I made a simple little panel to mount the adjuster knob next to the fuse panel. Two reasons, it can be reached by the driver and it keeps the cable short.
    I've got the dash and wiring harnesses wired and ready to drop in so time to get the forward firewall insulated and permanently mounted.
  40. #107
    Dec 2021
    Flower Mound TX
  41. Likes Railroad, Yama-Bro liked this post
  42. #108
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Nice Job! I just finished mine too and it's in about the same area.
  43. Likes Mike.Bray liked this post
  44. #109
    Dec 2021
    Flower Mound TX
    POL List Update
    My POL list wasn't bad, only about 20 line items or so. Of that I only really only needed 8 line items, I can source nuts and bolts. As of yesterday I'm down to three items, none of which are critical to finishing the car. For me it's a very good feeling knowing if FFR were to go belly up or something (which I doubt they will) I'm not dependent on them to finish my project.
    Now on the wrapping up the electrical!
  45. #110
    Dec 2021
    Flower Mound TX
    Full bore into the electrical now.
    Guard Dawg pushbutton start
    RT turn signal (button is horn)
    Pushbutton Head Lights
    Pushbutton High Beams
    Pushbutton E-Stopp Emergency Brake
    Pushbutton Flashers
    Pushbutton Seat Heater Controls
    Pushbutton Trunk Release
    Tail lights, brake lights, and rear turn signals all check out.
    Fuel pump runs.
    Dash lights all work.
    I found these really cool Lumen LED headlights with switchback halo.
    Here they are with the white halo for daytime running lights
    Here's they are with the amber halo for the turn signal
    And here they are with the low beams on.
    With these headlights I'm thinking of just eliminating the little round turn signal lights FFR supplies. Would require some bodywork to remove the raised boss, opinions?
    Now on to troubleshooting the courtesy lights....
  46. Likes 460.465USMC liked this post
  47. #111
    Aug 2019
    Spokane, WA
    Hey Mike. From your list it looks like you're putting together quite a custom setup on your electrical controls. Nice!
    I have the same headlights. I wired the white halo function as DRLs, connected to the unused accessory output of my Digital Guard Dawg. So, they turn on with ignition. I kept the round turn signal lights, but converted to LED. All preference choices, of course.
    I'm not a fiberglass/body guy, so can't help on your delete round turn signals question.
  48. #112
    Aug 2022
    Portland, Oregon
    Opinion-Just for the true look, install the lights, just don't make them functional since you got what you need.
  49. #113
    Dec 2021
    Flower Mound TX
    Since the electrical is pretty much done, or as far as I can go for now, been bouncing around some taking care of little things. The PS rear wheel wouldn't go on the pin drive adapter so took it apart, cleaned everything, reassembled, and very carefully torqued the pin drive lugs incrementally. Now the wheel slips on and hoping I get rear tires mounted tomorrow.
    Drilled & bolted the Breeze roll bar so that's out of the way. Bit of a PITA.
    Started on the trunk aluminum since the wiring is run and tested.
    I've got my own personal Rosy the Riveter.
    She pretty handy with drilling and Clecos too.
    Next it was on to bleeding the brakes. I decided to use a pressure bleeder as I've never had much luck with vacuum bleeders. Maybe they're okay with calipers that have a single bleed port but Wilwoods have 4 bleed ports.
    I deviated from the instructions some in that I only used it as a pressure unit, I didn't fill it with brake fluid. I'm not in that big of a hurry, I can refill the reservoir a few times. First I pressurized the front brakes with air only and used soapy water to check for leaks. All good so added some DOT 4 fluid to the front reservoir. I opened the bottom bleed screws on the PS caliper and let it gravity bleed while I ate lunch. After lunch I topped off the reservoir and pressurized it to 15 PSI. Worked my way from the bottom of the PS caliper to the bottom of the DS caliper and them back to the top of the PS caliper and finally the top of the DS caliper. Topped off the reservoir and repeated bleeding the top side of the two front calipers a few times. Then I did the same procedure with the rear.
    Right now the pedal is okay, I can feel a little residual air in the system. A few more rounds of pressurized bleeding should get them very close.
    Right now my goal is to drop the engine & transmission in the week of Labor day. I think I've got a shot at making that.
  50. #114
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Nice job man.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  51. #115
    Aug 2022
    Portland, Oregon
    The Wilwoods should have only 2 bleed ports per caliper, Upper inside and upper out side. Bottom would only be used if you wanted to drain old fluid and refill with fresh.
  52. #116
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by F500guy View Post
    I started out decades ago using JFZ calipers and John (owner of JFZ) told me air can get trapped in the bottom part as the inlet is centered. So I've always bled the bottom ports first and then moved to the top to finish. Since Wilwood basically copied the JFZ design I don't know why the Wilwoods would be different and seems to have worked for me over the years. What harm can it cause?
    Edit. The original JFZ design was fed from the inside center the same as the current Wilwood. The bottom ports were connected from one side to the other with a steel tube so the fluid entered the side, flowed down, through the tube, and up to the other side. John told me it was best to crack the tube fittings on the bottom to let any trapped air out before final bleeding using the top bleed screws.
    Wilwood updated the design to add internal porting from one side to the other. JFZ was a small operation and making that crossover tube would have been time consuming which is why I think Wilwood went to internal porting and four bleed screws for higher production. It may be true with this design you only need to bleed from the top screws, I haven't talked to Wilwood about it. But like I said, what can it hurt?
  53. #117
    Aug 2022
    Portland, Oregon
    I had some old Sierrra calipers with the external cross-over as well, still never used the lower ports. Your assistant needs a pneumatic rivet gun, good think you are not doing stainless rivets
  54. Likes Mike.Bray liked this post
  55. #118
    Dec 2021
    Flower Mound TX
    Turns out my personal Rosy the Riveter is also pretty handy laying and trimming carpet.
    I decided to go with the Nitto 555G2 tires as this is a street car. I like the way they look.
    After 2+ months of 100+ temperature days we finally got a break last night with a small front that came through. So I'm planning on taking advantage of the cooler weather for the next few days and hoping to tick a few things off my to-do list.
  56. Likes CaptB, rustyrim liked this post
  57. #119
    Dec 2021
    Flower Mound TX
    Still bouncing around checking little things off my to-do list. Spent today on seats.
    First thing this morning I installed the Forte seat heaters. It was a lot easier than I was expecting and a shout out to Papa and his post #297 for some great tips. Got both seats done in about an hour.
    Ran the wiring in the car, used the lap belt/bracket as a ground source.
    From there installed the Breeze seat mounts, I like these a lot. Then fitted the seats and did the required Zoom Zoom.
    And finally powered up the heaters and the wife said her butt was getting warm so must be working. Or a hot flash.....
  58. Likes toadster liked this post
  59. #120
    Dec 2021
    Flower Mound TX
    The wife is all buckled in and ready to go Zoom Zoom.
    Also got the carbon fiber transmission tunnel cover test fitted.
    Today I removed the car from the dolly, and asked myself why I made the dolly so tall. A floor jack, some 4x4's, and a cherry picker got the job done. After three months of looking at it and working on it up in the air this is going to take some getting used to.
    Now a couple of small things to take care of and it's time to drop the engine & tranny in.
  60. Likes CaptB liked this post
