Thanks Thanks:  9
Likes Likes:  51
Page 2 of 2 FirstFirst 12
Results 41 to 65 of 65
Thread: Narly1's Speedstar build
    Jun 2020
    SoDak
    Quote Originally Posted by narly1 View Post
    So the completion kit came today. It's all been inventoried with only 1 POL item, that being the fuel tank vent gasket.
    There does seem to be a mix up though in terms of what was sent for engine/transmission mounts & driveshaft vs what I need for my 302/AOD combination.
    I'm sure we'll get that sorted out in short order.
    Earl
    Long time coming Earl, congrats!! I look forward to watching your build.
    Jim
  2. Thanks narly1 thanked for this post
  3. #42
    Kingsland, TX
    I'm having an issue getting my 302/AOD mounts, brackets, hardware as well. Also J-pipes... I've also been told that the shorty headers are on backorder.
  4. #43
    Jun 2018
    North Vancouver, BC, Canada
    For the 302 block, these are the BBK headers you want
    https://www.summitracing.com/parts/bbk-15150
    Gen 1 '33 Hot Rod #1104
  5. Thanks narly1 thanked for this post
  6. #44
    Kingsland, TX
    Yeah, I've got those on my Summit Wishlist, but I paid for a complete install kit.....
  7. #45
    Oct 2019
    Erin, Ontario CANADA
    Prepping suspension parts for powdercoating this morning. Polishing the sharp edges and weld spatter out of the unpainted pieces with the exception of the front lower arms which after disassembly are sitting in solvent to wash out the grease in them first.
    I feel bad about undoing somebody's work, but it has to be done. All of the rear pieces came powdercoated black with their bushings, sleeves and zerk fittings installed. They will be getting the paint strip & polish treatment as well.
    Earl
    1st Speedstar in Canada 31 March 2023.
    Built by me 302 engine, AOD trans, 3.55 IRS.
  8. #46
    Oct 2019
    I separated the body from the frame and made this raised table on wheels for it to sit on. That way I can store it over top of the frame and wheel it out of the way when I need to work.
  9. Likes JimLev liked this post
  10. #47
    Oct 2019
    I ordered my fame bare as I wanted something different than black.
    So I've taken it upon myself to clean up any sharp edges and weld spatter as the first step before powdercoating.
    One positive outcome of this is that I'm getting a good understanding of the frame layout and a real appreciation for the workmanship that goes into them.
    Beautiful.
    Apologies for the surface rust, an unavoidable consequence of the long, wet drive home and monsoon season here in southern Ontario.
    Note that I've been using what are known as "surface conditioning" discs for the clean-up. If you never used them, they're like scotchbrite pads on steroids.
    Earl
  11. #48
    Oct 2019
    I should also give you an update on my POL situation.
    Parts have been dribbling in every so often over the past month. I have almost everything now except for the correct driveshaft and motor mount parts (got the wrong ones in error).
    My takeaway from this is that FFR's new inventory management system is making a difference. These parts delays are nothing compared to what I went through when I was building my engine.
    Earl
  12. #49
    Kingsland, TX
    I think that's the first time I've seen the Speedstar body in the raw. I didn't know the entire cowl was different! I though just the cowl where it meets the windshield frame. Which means the back edge of the hood and side covers is different too. this body will probably not look good without side covers.
    Guess I need to go look at the Speedstar gallery again...
  13. Likes narly1 liked this post
  14. #50
    Oct 2019
    Sometimes not working on the car is working on the car if you know what I mean.
    This past weekend's activity was a garage clean-out and yard sale. As a result I now have the extra space needed to move all of the parts boxes from inside the house into the 2nd garage bay, plus some stuff cramping my workspace in the 1st bay where the frame is.
    My car wanted its garage back, LOL!
    Earl
  15. Likes 33fromSD, Mastertech5, FF33rod, TxMike64 liked this post
  16. #51
    Oct 2019
    This past weekend's activity....
    I'll openly admit that I should have had this done long before the kit ever showed up, but building the new garden shed (that was also part of the garage clear-out/clean-up task) consumed all of my free time last summer/fall.
    At least I can say that I'm getting it done, there is light at the end of the tunnel.
    Earl
  17. #52
    Oct 2019
    Center section and C-hubs got a wash and coating of Nyalic.
    My first time using this stuff and I really like the results.
    Earl
  18. #53
    Kingsland, TX
    Earl
    Looks very similar to Sharkhide, similar price too. I heard about Sharkhide through a youtube channel I watch and was going to use it similar to you.
  19. Likes FF33rod liked this post
  20. #54
    Oct 2019
    Sharkhide seems to be a bit harder to come by up here in Canada. I found this stuff in a discussion somewhere about Sharkhide alternatives and it was given high praise so between that and the fact that a fairly local farm implement dealer carried it, I pulled the trigger.
    It's a bit on the runny side, like thinned out polyurethane, so you have to watch for drips on the underside of parts. Nyalic also sells a cleaner for their coating, not sure how critical it is that you use it, but I did after giving everything a good wipe-down with lacquer thinners as a degreaser.
    I really like the way it coats ferrous parts that would otherwise start rusting if not protected.
    Earl
  21. Likes TxMike64 liked this post
  22. #55
    Oct 2022
    Here is my Speedstar.
  23. Likes TxMike64, j33ptj, theidlemind liked this post
  24. #56
    Oct 2019
    "Date with the Devil": prepping the frame for powdercoating
    I say this because:
    1. The devil is in the details.
    2. Some of those welds (and there are a ton of them) are the devil to get at.
    3. I somehow managed to mess up my back and it hurts like the devil.
    Nonetheless I'm pressing on, I added a few vacation days onto the long holiday weekend and have made some great progress cleaning up weld spatter (surprisingly little), sharp/rough edges & welds, and the little laser cutter lead-in/lead out pips left behind on the plate steel parts.
    I'm hoping to be at the point where I can flip the frame upside down on the weekend to catch the last little bit.....then it's off to the powder painter's shop.
    Earl
  25. Likes FF33rod liked this post
  26. #57
    Oct 2019
    Still working on the daily grind. This back pain thing is really slowing my progress. I'm at the point where I do what I can when I can. Getting close to being able to flip the frame over though.
    In other news I managed to score a used air rivet gun in almost new condition for $40.
    Earl
  27. #58
    Simi Valley, CA
    I can sympathize with your back pain issue. I had 3 surgeries during my (still ongoing) build and am now fully fused from L2 to S1. I hope yours doesn't come to that.
    Keith HR #894
  28. #59
    Oct 2019
    Keith HR #894
    I've been doing physio and getting great immediate (after visit) and encouraging between visit results. Part of the issue I'm having goes back to when I broke my femur. Scar tissue. Everything relates to everything, the human body is a finely balanced machine.
    Earl
  29. #60
    Simi Valley, CA
    Yup. Everything is connected and there are always unintended consequences. Now that my back is fully fused, I'm having trouble with my sacroiliac and hip joints. I just succeeded in moving the problem to another area. That's why I suggest continuing with PT and exercise as long as you can.
    Keith HR #894
  30. #61
    Jun 2020
    SoDak
    Yup, my back doctor tells me some time in the next 5-10 years I'm going to need surgery for L3-L4 pinched nerve issues (lose complete feeling in my right leg down to the knee which is kind of scary). We've figured out if I can get an epidural injection every 4-6 months in that L3-L4 area and then continue on with daily exercises me and my PT worked on I can prolong the "S" word for a few years, maybe longer. Been almost a year now (just got another injection the other day) but eventually they tell me injections/PT just won't do it any more.
    Keith & Earl, I feel your pain (excuse the pun), we do what we can do, when we can do it, sometimes our bodies just don't cooperate anymore.
    Jim
  31. Thanks narly1 thanked for this post
  32. #62
    Oct 2019
    Disappointed and a bit embarrassed that I've made almost zero progress since my last update due to the back pain thing. Almost 2 whole months lost! No joke. The good news is that I'm starting to feel more like my old self again. The frame is flipped upside down at the moment so I can get at the last of the welds and clean them up. While it's in this attitude I'm going to drill the outer floor panels. I've decided to delay powder coating the frame until much later in the build process.
    Earl
  33. Likes FF33rod liked this post
  34. #63
    Simi Valley, CA
    I also went with the bare chassis, since I planned to do a lot of customization that would require welding and structural modifications. However, I recently recognized that I went too far down assembly road before tearing everything off for powder coat. Stuff gets much more complicated when you make it to be removeable and easily reassembled. Also, I found that it could be difficult to get all the rivet holes to line up if I had to mount panels several times, so I recommend that you not pre-drill the rivet holes.
    I suggest that you make a detailed plan of the chassis mods you want to make and make those a priority - then get the chassis powder coated as soon as you can fit it in the budget. Life will be easier and you won't have as much to do twice.
    Have fun with your build!
    Keith HR #894
  35. Thanks narly1 thanked for this post
  36. #64
    Oct 2019
    Keith HR #894
    Thanks for the great perspective. Not looking to do anything crazy, I just want to make sure that the sheet metal drilling, brake/fuel lines and a few other misc brackets are sorted out before painting.
    Earl
  37. #65
    Kingsland, TX
    Earl
    I know how you feel - I'm just now getting back to work on mine after about 3 or 4 months... But I don't have any health excuses. It's been hotter than hell this year and I couldn't manage. Work and kids/family are my main excuse. But I'm happier to be back working on it.
    Glad to hear you're back at it as well!
  38. Thanks narly1 thanked for this post
