Results 1 to 2 of 2
Thread: Hydraulic TOB HELP
    Jul 2020
    Spencer, MA
    Hydraulic TOB HELP
    Has anyone used this TOB on their build? It's a GM bearing that comes with a complete kit, flywheel, clutch assembly, transmission and blowshield. I bought them all separately from different sources because the blowshield was on backorder. It seems obvious to me that the TOB must be held in place when the trans is installed because the fittings won't fit through the hole in the bellhousing. I have the spacers all set for the proper clearance to the clutch fingers. My problem is the orientation. I've seen it like I have it but a guy on YouTube had the anti-rotation stud at 4 o'clock instead of at 2 oclock. The hose kit has a bleeder hose with straight fittings and the supply hose has a 90 deg. fitting on one end. The hoses fit better to exit the opening in the bellhousing when the stud is at 4 o'clock but the bleeder wouldn't be at the top for the best way to get all the air out when bleeding. Any suggestions or opinions? Speedway tech support is off on the weekends, where I bought the bearing and hoses.
    The bleeder has to be the top one. But the two connections are interchangeable. They can be either bleeder or slave. At least they are on the Tilton one I used. You should be able to switch hoses and get the proper orientation.
  3. Thanks Mastertech5 thanked for this post
