Well looks like we need a new category? So I will park this one here until there is one......?
How about a Factory Five towing a Factory Five !!
Nice brother........... and Happy Birthday to you.
Coil overs usually aren't good for towing or cargo payload. You plan on adding supplemental bags to the back?
Thanks! Not sure yet on the tow setup
I question if this utilization was part of the design intent. The Pre-Runner looks like a play truck, not utility. I see no cargo area and in the photo from early cab fitment, the tube frame does not look suitable for Class III or IV hitch.
Class III 300-800lb TW, 3500-8000lb GTW
Class IV 500-1200lb TW, 5000-12000 GTW
The plan to run lower ride height is appropriate in this regard.
The truck design has an integral tow hitch already as part
of the Factory Five design.. regardless of pic, the
truck has a bed. Should work just fine.
I was intrigued by this truck when I first heard about it earlier this year. Looking forward to your build.
Erik,
Is this a beta build? What are their plans for release? Cost?
Looks like fun!
Gen 3 Coupe #334 received 11/4/21. Coyote, IRS, TKX, Wilwoods
'02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb. Hoosier Cobra member (Hoosiercobra.com)
Short Block - confirmed and 5-6 week delivery time expected..... should be a great foundation! Only correction to this is that I upgraded to the GEN 3 block
Working on upgrades to the interior - I really like these Katzkin covers
Front seats done - mission complete - still some other upgrades I want to do - but this was well worth the effort!
Erik, did you install new foam under the seat skins, or just reuse what was already there? (If that's in the video, I missed it...just skimmed through it quickly here at the office.) Just curious -- I've been thinking about re-covering the seats in my 12-year-old daily driver truck, which are just starting to crack, but I wonder whether new covers will look property taut / stretched if I don't replace the seat foam as well. I very much like your choice of actual new upholstery, rather than all the cheesy slipcover solutions out there. Katzkin is nice stuff, and priced accordingly!
Look forward to more updates on your XT1 build -- for those of us with family and kids to haul around, it's the most exciting kit idea to come out of FFR in a decade or two!
Cheers, John
FFR10004105RD: Twin-turbo BMW V12 powered FFR Roadster
Currently garaging 2,600hp spread across 78 cylinders and 4 turbochargers
I used the foam that was in the seat... the only one that was damaged was the driver's side but on the inboard side? the outboard side was actually fine.
The other thing to consider about the foam. The F150 doesn't use hog rings - there are plastic rods in the cover and plastic clips in the foam - some of these broke while releasing the OEM covers from the foam.... the back was the worst.. almost all of them were broken... so I used black zip ties to pull the plastic rods into the foam... the fronts again strange, were fine - I think I only used like 2 zip ties there...
I almost did do the slip on covers - I am so glad I didn't now... drove it last night and the over driving experience is just "nicer".... and when you open the door it looks really good and not stock.
I did have to ice my hands after 2 days of installing it though...lol...I would not be excited to do this again... maybe invite friends next time.
Taking advantage of Cyber Monday - order these guys and save 400 bucks!
12's in the back and 9.5's in the front
plan on running
325/55/22's scorpions
Those will work great with the Gray body color!
It'll be interesting to see what a staggered wheel setup looks like on a pre-runner style truck. I like the wheel choice.
if you look real close at the FFR from SEMA it has a staggered setup - but I think mine is more staggered.
Quick update as parts slowing start to flow in
Just a quick update - been a very busy Holiday so this one will be quick - but just wanted to share what I have to this point.
E,
I'm calling the heat from the duct a non issue for the gauge---my recollection from way, way back when I was doing OEM automotive cooling system work with Schwitzer Corp. is that heater discharge temps run 120-130F. You and the gauge will see more than that inside the cab when the truck is closed up on a sunny summer day.
Keep the updates coming!
Boost has arrived - unpacking the turbo kit
Turbo system cold mock up
Small update.... the foundation of the build is
finally making progress...
mores stuff getting prep'd - block should ship next week.... then all that is left is the actual kit and to get the transmission upgraded - will do that after teardown....
I AM BACK!
Got the call from Stewart Transportation this week that the BETA XT1 Truck would ship next week - so the teardown begins TODAY..... will be another full video documenting the build as well as pictures along the way. Here are some already - I only spent about 4.5 hours on it today - It really came apart a little easier than I had expected - but so far so good.
WOW - all day on the teardown - I am absolutely beat - but you can pull the chassis off the cab in the garage and you don't need a lift.... lol . Will be pulling the engine and transmission out tomorrow -
Here is some day light:
The Sled -
I used 3 harbor freight chassis dollies .. the 3rd one is under the spare tire.
back on the wheels and in the garage
Cab all done and outside...
Quick day of it - got the transmission out which was the main goal for this part of the build - anyway cleaned some more but at least we have most of it all torn down and ready for the kit arrival next week.
You're A Better Man Then Me Sir Erik!
Way, Way, Way Better!
Good Luck!
Erik, just curious -- if it's in the videos, I apologize. Once the passenger cab is ready to be lifted off the chassis, how much would you estimate the cab weighs? I saw you mentioned removing it without a car lift. Thanks!
I remain anxious to see the beta chassis and kit arrive for your assembly, and I'm glad that the XT1 project hasn't lost traction. I'm really hoping they revive work on the F9 at some point, too.
Cheers, John
I am not sure how much the cab weighs - it has to be at least 1000 lbs I would think if not more.
We are officially a Factory Five XT1 owner! This truck is massive!! The unloading went very well- no issues at all. The packing job was fantastic and easy to manage and follow - still have to unpack some more this weekend - but I need to get the body and chassis put back together first.... This will be the priority this weekend.
Anyway - tried to capture everything in the video from today - it's a long one - but all in all I spent about 1 hour and half unloading and another 3.5 just exploring
Here we go folks!
Thanks for the effort with the video and documenting the build! Following along with keen interest.
Mk III 4880: 3:55 - 3 link, T-5, 347, Holley Sniper/dual sync distributor, Comp Cams XE274HR, Edelbrock RPM Heads
Day 1 of honest assembly - got quite a but done. Mainly and up front I got the body and the chassis back together and moved back into garage (out of the sun). After that got the good on so I could get that thing out of the way! It fit perfect!
Next on the list was to prep the gas tank with all the go fast stuff.... I also got all the suspension components out of their respective boxes and ready for powder coating next week.... more to come tomorrow .... I broke my own rule today and only planned one thing today.... so I wasn't as productive as I could have been..... tomorrow we have a LOT lined up. Stay tuned!!
Wow! Erik, you make it look so easy! This is fascinating. I look forward to the next installment!
Day 2 of assembly - got almost everything I wanted done this weekend - but ran into a snag - so I will regroup a little this week... just part of it a guess.
Wow, you keep busy! When is the fence getting re done? Lol
Higgy
MK4 #11012 picked up 04/16/24
351W, 3 link, single roll bar
MK4 #10616 picked up 4/10/23
MK4 #9759 picked up on 4/3/19
A few more parts on the truck after work; Main and Rear Electrical harness in as well as the gas tank.
Day 3 had just a little progress - had to work most of the day but did manage to get the brake system moved over and install half of the timing chain guides.... but it is progress nonetheless !!
"I have to have a plan before I get started -- otherwise, I just walk around and waste time." A truer statement about garage time has never been made!! It's awesome following your build process. Thanks again for these posts.
Cheers, John
