Results 1 to 5 of 5
Thread: Please Read My Gear Marking Compound
    Senior Member Dave 53's Avatar
    Jun 2020
    Danville CA
    After blowing out my ring and pinion gear last weekend on my 818, I'm about to button up repairs. I didn't put in this much effort last time and that might be why they failed. I probably had too much backlash last time. This time I got a proper dial gauge and gear marking compound.
    The learning part of the project was learning to read gear marking compound.
    My read is this is pretty good looking. Backlash is .13mm - the tight side of the .13 to .18 FSM range.
    Looking for feedback from those that have experience in this.coast side.jpgdrive side.jpg
    Syracuse, NY
    Quote Originally Posted by Dave 53 View Post
    ...Looking for feedback from those that have experience in this.
    Done this many times on various differential types and your mesh pattern looks spot on!
    Question, did you secure the ring gear to the differential using Loctite? I only ask because I've had Subaru ring gears loosen up in the past.
    MK3.1 Roadster completed 2011
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    That looks text book correct. Follow the gear manufacturers directions as to torque, bolts, break in and Loctite requirements and you shouldn't have any issues.
    Pittsburgh, PA
    That looks right on the money. I don't have tons of experience but what I've done has been successful so far, for what it's worth.
    Jun 2020
    Danville CA
    Thanks for the feedback! I didn't have confidence in my read and now I'll breath easier.
    The FSM makes no mention of Loctite, but it couldn't hurt and I will take your advice.
