Thanks Thanks:  5
Likes Likes:  46
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 89
Thread: Bill Elliott's "Living the Dream" build thread.
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    Quote Originally Posted by Bill Elliott View Post
    I will also say that silicone is anti-seize compound's evil twin. That stuff gets everywhere.
    I couldn't agree more. Pretty sure anti-seize and silicone jump from the applicator to my hands when my head is turned.
    You're cruising right along. Nice to see you have a lift...so helpful. Keep up the good work.
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  2. Thanks Bill Elliott thanked for this post
  3. #42
    Jan 2023
    Woodway, TX
    This showed up, very excited to try it out.
    Delivery Date 6-24-23 Build thread Living the Dream
    SBF 427 564hp/576tq Holley Sniper with Hyperspark by Smeding Performance. Tremec TKX .68 OD. IRS . Wilwood 12.88 brakes. Wilwood EPB. First start 11-17-23. First go cart 11-20-23.
  4. #43
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    Bill, Here is what I was planning on doing with the EPB wiring-Zip Tie the stress relief and route to the frame above the upper a-arm with enough slack to not get pulled by the wheel movement, then get into the transmission tunnel.
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
  5. #44
    Jan 2023
    Woodway, TX
    Quote Originally Posted by F500guy View Post
    Yea, I think we have to have a way to secure it but still allow enough slack for suspension travel without interfering with the springs.
  6. #45
    Jan 2023
    Woodway, TX
    Things were slowed a bit, waiting on the brake line and brake line bending tool. Those just came in so will be back on that shortly.
    I have found that I waste soooooo much time looking for parts, hardware, and tools. Today I spent pretty much all day looking for something simple, 1/8 aluminum sheet to mount reservoirs - none to be found in town , only needs about 4x6 inch piece. 1/8 npt flush plug to plug the back side ports on said reservoirs, none available at Ace , Autozone, Lowes. I would be a bit further on things if I didn't have to wait on everything. Oh, well give me more time for planning.
  7. #46
    Bill,
    I use onlinemetals.com. You'll usually have it in your hands in 2 days.
  8. Thanks Bill Elliott thanked for this post
  9. #47
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    Looks great! I'm just behind you with my progress. Kit was delivered 7/11/23, and I've buttoned up the front suspension and all the IRS bits, as well as drilled all the panels and got them powdercoated. I'm starting the pedal box this weekend.
    Built an early MkIII years ago, sold years ago.
    Got Corvettes out of my system, and now back after 18 years to build a MkIV.
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, 427 Stroker, Holley Sniper 2, Hyperspark, TKX, IRS, Wilwood Big Brakes
    Here to learn, contribute, and have fun!
  10. Likes Bill Elliott liked this post
  11. #48
    Jan 2023
    Woodway, TX
    So I was able to finish fuel line except for the connection that will go to Sniper 2 and put a clamp on passenger footbox. Tomorrow I can start redoing my brake lines. Then start electrical. I also put the breeze front mount battery box in and started laying out the wire harness.
  12. #49
    Jul 2021
    Tonganoxie, KS
    I really dig those fuel lines and clamps. Can you tell me more about what you did (parts, brands, etc)? I'm going with a Coyote engine.
    Greg
  13. #50
    Jan 2023
    Woodway, TX
    The line is from Hot Rod Fuel Hose AN-6 size for feed and return. The clamps are from Amazon , not sure how well they will hold up on the finish. I tapped the metal with a 10-32( learned the hard way that the original 6-32 screws that the clamps came with were to small ), also had to drill out the hole in the clamp to accept the 10-32 cap screws.
    https://hotrodfuelhose.com/collections/bundles
    https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
    I see your near K.C. , I love Q39 Barbecue, and Jack Stack
  14. #51
    Jan 2023
    Woodway, TX
    Back to the brake lines. I must say this has been the most humbling part thus far. I have a really good tool now for bending. The Ridgid lever type bender works really good. "Mistakes were made...." . I said before that nicop brake line is reasonably priced. Well, that is dependent on the number of mistakes you make. I got confused on measuring several times with the radius and whether I was bending towards the fixture or away. Very easy to goof up, at least for me. I am getting lots of practice. Definitely better than my first attempts though.
    now front drv brake line 3 (Medium).jpg front drv brake line 2 (Medium).jpg front drv brake line (Medium).jpg
    Still have to put cushion clamps on. Tomorrow will be passenger side front. Also, now I know what those coiled brake lines are for, people like me that measure twice and still end up with extra
  15. #52
    Senior Member Nigel Allen's Avatar
    South Australia
    G'day Bill,
    As an alternative to burning through so much nicop, try making examples of your pipe work out of fencing wire first.
    Start by grabbing a 12 ft length of fencing wire. Put one end in the vise and the other in the chuck of your battery drill. Pull the wire straight with a decent amount of tension on it. Then pull the trigger for 20 or 30 revolutions. You should end up with a very nice rigid and very straight length of wire. Use this to make your brake line first and then you can use it as a guide when you make the real thing.
    Keep livin' the dream.
    Nige
    Gen1 Coyote / TKO600 / IRS
  16. Thanks Bill Elliott thanked for this post
  17. #53
    Dec 2021
    Flower Mound TX
    Maybe this will help you with the Ridgid bender. Once you figure out thr reference marks on the link you'll be gold.
  18. #54
    Jan 2023
    Woodway, TX
    Small updates here. I finished the front brake line going from driver side to pass. side. I mounted the Scott's Hot Rod reservoirs also. First one I did was not exactly level so I scrapped that and the final one is level.
    front brake line driver (Medium).jpg brake line front view (Medium).jpg front brake line pass.jpg brake reservoir (Medium).jpg
  19. #55
    Jan 2023
    Woodway, TX
    Finalized the brake lines today. Hit a bump in the road. My lift has a leak from the quick disconnect fitting. I will have to get that replaced asap. Next will be to fill and bleed the brake system.
  20. #56
    Jan 2023
    Woodway, TX
    Brake system is complete. Bled master cylinders on car with a short line from the master to the reservoir. Then vacuum bled all the calipers. The rear has an inboard and outboard bleeder , outboard first then inboard. The front was just the top bleeder. Pedal feels good, about an 1 1/4 pedal travel right now. Not a single leak from any fitting first time !!
  21. #57
    Jan 2023
    Woodway, TX
    Started putting gauges in dash. Mocked it up. The carbon fiber is easy to cut but dusty. I was all suited up for it, I have had my run in with fiberglass before so didn't want the itches afterwards.
  22. #58
    Jan 2023
    Woodway, TX
    Glove box definitely goes on my NOT FUN list.
  23. Likes John Ibele liked this post
  24. #59
    Jan 2023
    Woodway, TX
    I have a few days off this week and next week. I think that will allow me to get some real progress done since most of the time I have been working randomly after work.
    So I have been working on the dash and wiring. I purchased some good crimpers and am using 3:1 heat shrink on all connections, this is a part I really enjoy doing.
  25. Likes Mike.Bray liked this post
  26. #60
    Dec 2021
    Flower Mound TX
    Be sure and run all of your dash wires to Weather Pack connectors so it's easy to remove later.
  27. #61
    Jan 2023
    Woodway, TX
    More and more wiring, lots of time will be spent on this. I spliced in the tail light converter it will be behind the dash for easier access if ever a replacement is needed. The extra purple wires that are unused and conveniently already run in the loom to the back I might use for trunk lights and a back up light. I am also thinking about one of those plasma brake lights like Travis put on his.
  28. #62
    Jan 2023
    Woodway, TX
    Look what showed up today
  29. Likes danmas, cc2Arider, zarnold liked this post
  30. #63
    Jan 2023
    Woodway, TX
  31. #64
    Jan 2023
    Woodway, TX
    Today was the big day. Engine install. I can say it was flawless , super easy. I used a 2ton hoist with a leveler that worked really well. https://www.summitracing.com/parts/WMR-W41036 . I installed the transmission bracket before putting the engine in and it was not a hindrance at all. I also put the driveshaft in the transmission tail just before the engine was all the way down, that is absolutely the easiest way for the driveshaft. I don't know why so many people fight with that after the engine is in place. Just a great day , everything went as planned. Good help to from a few guys.
  32. #65
    Jan 2023
    Woodway, TX
  33. #66
    Apr 2021
    Park Ridge, IL
    Congrats! When is first start?
  34. #67
    Jan 2023
    Woodway, TX
    still have to finish electrical ie. Holley sniper , all plumbing including radiator. Hopefully within 3 weeks. Can't wait to hear it.
  35. Likes Mike.Bray, zarnold liked this post
  36. #68
    Jan 2023
    Woodway, TX
    Today I got the driveshaft torqued down , waiting on some spaces to set pinion angle. Have put accessories back on the motor. Put the ground strap to the block on. I posted on main forum asking if this is ok the way I did the grounds.
  37. #69
    Sep 2011
    Minneapolis, MN
    That's the way I did mine, one from the engine to the frame, and another from the starter post to the frame. I haven't had any electrical gremlins to chase down with my Sniper setup. Good progress and nice looking engine.
  38. #70
    Jan 2023
    Woodway, TX
    Now that I have the engine in there is a long list of things that can be worked on in no specific order with the goal of first start on the horizon. Today I finished the mechanical throttle linkage. The roll pins that came with the kit I thought were 3/32 but I just couldn’t get them to work. I went to Ace and bought some 1/8 roll pins and put them in with no problems , cobalt bits for that ss rod is a must. I was also able to finish up the fuel lines up to the Sniper. I removed the fuel pressure regulator from the Sniper as I am using an external regulator. There has been issues with the internal regulator in the Sniper so I wanted to eliminate that issue now.
  39. Likes zarnold liked this post
  40. #71
    South Australia
    G'day Bill,
    Engine bay looks great. Might be worthwhile putting a PVC boot over the positive terminal of the alternator. The terminal lurks there waiting to short to an errant spanner.
    Nige
  41. #72
    Jan 2023
    Woodway, TX
    Thanks for that idea, i only have it laying there right now , still have to size it and put some loom wrap on it.
  42. #73
    Jan 2023
    Woodway, TX
    Another milestone passed that helps me sleep better at night. I received the transmission spacers today so went to work on driveline angles. Started with all three spacers though it was good then realized not everything was tightened down yet so back and forth a bit after that with checking, tightening rechecking. Ended up using 3 spacers and two washer and finally success.
  43. #74
    Jan 2023
    Woodway, TX
    First start
    Edited version< only issue I had was the clutch safety switch. I had to tighten some hose clamps and also the thermostat housing. My Summit expansion tank has a small leak from the sight tube on the side. I think if I take the fittings off and put some teflon tape on it should be good. After I restarted a couple times it started burning really rich afr was a 35 which is really high. This will be a learning curve trying to get settings on the Sniper all tuned it but initial start was awesome !
  44. #75
    Apr 2021
    Park Ridge, IL
    Sounds great! Nice work!!
  45. #76
    Jan 2023
    Woodway, TX
    Been a while since I have posted here. December is a bad month to be a mailman. All my car building time was taken up by Amazon.
    Past few weeks I worked on minor things, go-carting and checking things. Making sure all mechanical issues are ok. I set my ride height last week, so now I am trying to make plans on getting the car to a shop for a accurate alignment. At the same time I will probably rent a enclosed trailer, I want to see what size, if any, that I can fit between my garage and a fence.
    Today I worked on the courtesy lights that are switched from the headlight switch. I also had to connect the inertia switch at the back of the car near the fuel pump because I have my pump powered by the Sniper. I also wired in a connection for a backup light, just have the wire there ready for the light that I will choose later .
    I have driven the car several times just in the neighborhood and everything is great just can't wait to get it on the open road. Next thing I have to do is get some switches mounted under the dash (high beam, hazard lights), and a place to mount the seat heater switches and a usb/12v charger.
    One last thing,,,, I installed the horns also. The provided female connector that you are supposed to use and make a jumper from one horn to the other with does not work. The way the instructions show you would have to put 2 14ga wires into 1 blue female connector that is made for 1 14 gauge wire. Don't know why they don't provide a connector better suited for that. So I switched that to a 10-12 ga connector.
  46. Likes F500guy liked this post
  47. #77
    Jan 2023
    Woodway, TX
    Cup holders and transmission covering are in progress now. Tonight I applied the 1/8" closed cell foam. Used the 3m 90 contact adhesive, easy to use and fast. The white box behind the cup holders is my model of what I want for mounting my seat heater switches and usb charger. I took it to a local shop here https://www.cmlaserandfab.com/about-us. Hopefully they get to it soon.
    Next weekend I have a trailer reserved 8.5 x 16 enclosed, to take the car to someone to get a good alignment done. This will also allow me to see what size trailer I can fit between my garage and the fence with gate. It will be a snug fit as the front corner of my garage to the fence is 114" and the trailer is 102" . So its more of what size trailer I can maneuver in there than what size fits.
  48. #78
    Jan 2023
    Woodway, TX
    Got my alignment done yesterday. Real happy with that done now. I know some guys at our local Ford dealership , he was able to come out on his own time to do it for me. Didn't take a whole lot of work. I was suprised my intial eyeball setup was at about 10-11 degrees on caster. All good know at 7.5 degrees. Camber is at -.5 and toe in about 1/8 inch.
    Today finsihed up a custom shift boot. I might look for a different shifter ball. The boot is made from the same material as the trans tunnel cover
  49. #79
    Jan 2023
    Woodway, TX
    Getting close to mounting the body. I installed 2 kayak hoists to raise the body and slide the car under it. I wanted to be able to do this by myself.
    I made a model of what I wanted to mount some switches and a USB charger/ 12v port. I had a local shop here that took my model and created a cad drawing and formed the part for me. I then covered it with the leather I used for trans tunnel. Really pleased with the finished product. It's nice to see my own visions become reality.
  50. #80
    Aug 2022
    Portland, Oregon
    Very nice Bill, you are flying thru your build and looks great!
  51. Thanks Bill Elliott thanked for this post
