Thread: Clutch m/c access
    Clutch m/c access
    I've got about 4k on my 818s. My clutch pedal seems a bit soft. I want to bleed the system. Any tricks to accessing the clutch reservoir? Should have installed a remote during the build. Do I need to remove the windshield?
    Feb 2019
    Houston, TX
    You can trim the windshield surround to make a door. I can't find pictures of mine and I'm out of town, but basically you can cut a rectangular hole to reach through. If you do it neatly you can use the piece you cut out as a door to cover the hole.
    Thanks, I thought about cutting the surround, but I always get a little nervous when I start cutting. When you get home, maybe you can send some pics
    Feb 2019
    Houston, TX
    Quote Originally Posted by tgf05354 View Post
    Will be thanksgiving.
    No problem, car is put away for the winter
