Results 1 to 7 of 7
Thread: IRS CV Joint
    Colorado Springs
    IRS CV Joint
    This axle is not from my Cobra, but it's pretty typical of all modern IRS axles. The stock Ford parts are a little different. But most heavy duty aftermarket parts look like this. I'm pretty sure, anyway.
    After 8 seasons of racing this car, I noticed that the left CV joint was rattling a little bit. Not much, just a little. I took it apart to see what was going on.
    Assembled, the joint looks like this.
    Disassembled, it looks like this.
    When I opened mine up, it looked like this. Even though this is sealed, and had no leaks, it was all dried out.
    After taking it all apart and cleaning everything, I find a lot of wear in there. Look at the top center, where the ball bearings impact the gear.
    I greased it up, and put it all back together. I flipped the bearing cage over, so the thrust surface is now on the other side, where there is minimal wear.
    I'm contacting The Driveshaft Shop to see if I can get some new ones. Might as well replace them both at the same time.
    So, what's the point? The point is, I should have been taking the axles apart for cleaning/lubing on a regular basis. If you have this type of CV joint, you should too.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Norton, MA USA earth
    Is this a T-bird IRS? haven't seen axles like that recently.
    Senior Member weendoggy's Avatar
    Aptos, CA
    Exactly! Looks like the newer or some modified version to replace them.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Colorado Springs
    The Ford T-Bird joints haven't been made in years. They are difficult to come buy, and can't handle a ton of torque. This Porsche style replacement is pretty common these days.
    .boB "Iron Man"
    Aptos, CA
    Quote Originally Posted by Bob Cowan View Post
    Yep, see a lot of these. Didn't know someone fiugred out the joint/axle combo for the Cobra's. I do have a new set (axles) of the old T-Bird style in stock.
    Senior Member Its Bruce's Avatar
    Houston TX
    Where did you source these replacements for the old 8.8 IRS?
    MK4, 427LS3, IRS, T56 Magnum, Wilwoods
    Colorado Springs
    The Drive Shaft Shop
    .boB "Iron Man"
