Results 1 to 3 of 3
Thread: Gen 2 Coyote Oil Drain Plug Size?
    Senior Member D02G's Avatar
    Mar 2019
    CT
    Does anyone know the size of the rear facing oil drain bolt on a Gen 2 coyote with the Moroso pan?
    MK IV - #9586, Gen 2 Coyote, TKO 600
    I've used that pan on a couple builds, but never paid attention to the thread size other than replacing the 1/2-inch ID (M12) copper crush washer each oil change. Per Moroso's website, "1/2" NPT fitting for supercharger/turbo drain back, and 1/2" NPT fitting for oil temperature sender 20 mm fitting for factory oil level sender." Looks like 1/2" NPT is your answer.
    Senior Member weendoggy's Avatar
    Aptos, CA
    My Holley pan came with a 1/2"NPT and I hate that for a drain plug. I drilled and tapped for a 18 x 1.50 standard oil plug with nitrile/metal gasket/washer. Nice!
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
