My '04 WRX was totaled in an accident on 04-05-13, front end damage, both airbags deployed, Driver's side is scratched up/dented, the windshield is cracked, drivers side rear taillight is cracked, small dent bottom center of trunk. Selling it for parts.
Selling as a whole for $5,000, this is a firm price.
Engine starts up just fine. Trans shifts through all the gears smooth.
78,445 miles
Parts of note on it:
PPG Synchromesh Straight Cut gears 1-2 and 3-4. Tranny was rebuilt 14k miles ago everything replaced with brand new parts, have receipts.
Cobb Anti-sway bar kit, Front and Rear
Cobb Sport springs
Cobb short throw shifter
STI seats and door cards, front and back
Tires, brakes(all 4 pads and front discs), shocks, struts and O2 sensor replaced 4k miles ago. Have receipts.
Did a lot of work 4 Days before the accident, Have receipts.
Items replaced with new parts:
timing belt
water pump with gasket
two smooth rollers/idlers bearing with bolts
one cogged roller/idler bearing
auto tension adjuster
tensioner bearing for auto tensioner arm
thermostat
thermostat gasket
two drive belts
four camshaft seals
front crankshaft seal
valve cover gaskets, grommets, half moons(driver and passenger)
spark plugs
cleaned the MAF and IACV sensors(replaced IACV gasket).
Fuel filter
Air filter
It is located in Paonia, CO 81428.
Email or call, text @ 97o-27o-oo22 if interested I will be happy to post more pictures talk with you about it.
Thanks everyone.
