![Boig Motorsports](https://thefactoryfiveforum.com/attachment.php?attachmentid=181712&d=1679150850)
0
0
Infinity Box Electrical Wiring System
This is for any one that has installed the Infinity Box electrical wiring system into a 33 Hot Rod with Vintage Gen II A/C system.
Where does the purple wire get hooked up to coming off the power relay, it shows being hooked up to the ignition switch, is this correct when using the Infinity Box?
Any help would be appreciated.
Bob Hunt
I have the Infinity Wiring in a Roadster with a Vintage AC but I don't know what purple wire or power relay your speaking about. More details would be helpful. The Infinity Wiring eliminates the need for most relays.
Infinity Box
Vintage Air Purple Wire
Originally Posted by
Dodgeman
Bob Hunt
Bob, the purple wire in the Vintage Air harness needs to be connected to the ignition output on your front POWERCELL. When the ignition is on, the purple wire has to get 12-volts. This closes a relay inside the Vintage Air controller and powers it up. You're only triggering a relay coil so the current draw is minimal.
The purple wire does the same thing on both the Gen-II and Gen-IV.
This blog post on our website gets you more details on wiring the Vintage Air system into Infinitybox.
http://infinitybox.com/wiring/vintage-air-wiring/
Please let us know if you have additional questions.
jharris
Jay,
Thanks for the information, this one really stumped me, I guess I should call you guys first when I am having problems since its your system.
Thanks again.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
